Problem with ABS after installing Bilshtein B16
Old Nov 12, 2013 | 09:29 AM
Budweiser's Avatar
Budweiser is an unknown quantity at this point
Sorry for my English, I'm not a native speaker.
After installing Bilshtein b16 pss9 (without damptronic) a problem with ABS has occurred. My car is 997 Carrera S, manual transmission, 2011, and it had a PASM from factory. I ordered B16 without Damptronic because I have an experience of adjusting this suspension on my previous cars, and I did not want electronic suspension. After installing suspension, even at low speeds, when I press a brake pedal (softly) ABS starts working. First we thought the problem was with cross balancing, but after we adjusted cross weight, the problem remained. When we disconnected PASM, sport mode stopped working. Our next guess was the electronics disfunction. I bought PASM cancelation kit from KW suspensions. After installing this cancellation kit the sport mode started working, but the problem was still there. I have no clue what to do. My local dealer is very stupid, he can only change oil and brake pads. So I can not get any help from them. They checked ABS sensors, and did not find any problems.
What are your suggestions? Can you tell me how to align the suspension rate? What height of front and rear axle, cross weight, weight distribution (front/rear) are needed? And how many clicks do you make to adjust front/rear axle? I made 3 clicks from stiff setting at front, and 5 clicks at rear axle. Thank you in advance.
My cross weight, after installing B16
FL 284.5kg FR 271.5kg
RL 454.5kg RR 450 kg
Front 38.07%
Rear 61.93%
Cross 49.73%
Old Nov 12, 2013 | 11:46 AM
81911's Avatar
Wrong forum for this info. I wouldn't waste my time. Find a specialty shop.
Tatanko
All Things Apple
10
Jan 24, 2012 09:26 AM
purple8gold
Jun 5, 2010 05:34 PM
SKYKING
The Team Speed Shooting Range
10
Jun 10, 2009 08:20 PM
bharrisy2k
Feb 20, 2009 11:25 PM
