Question regarding wheel diameter
Old Aug 4, 2010 | 12:36 AM
STLG's Avatar
So I'm in the very very early stages of getting new wheels for my G37S. At this point I have neither the money nor any specific wheels in mind, but I do have a question regarding wheel size. I know many of you have aftermarket wheels on your car(s) and figured I'd get a better answer here than anywhere else.
If I get bigger wheels than stock - say 20" instead of the stock 19s on it now - will I need to have anything besides the alignment checked/calibrated? My dad was telling me that I would have to take it to the dealership and have them do something with the tacho/speedo or it wouldn't read accurately because of the different size wheel. I've never heard this before, and he's a bit behind the times in general.
Thanks.
Old Aug 4, 2010 | 07:53 AM
Depends on what size tires you get. You'll need lower profile tires to keep the accuracy of the speedo in check if you go with bigger wheels.
I think tirerack.com has a pretty good explanation on how it all works and I bet they could suggest which tires to get too.
Old Aug 4, 2010 | 08:41 AM
jox's Avatar
jox
When you go up in wheel size, you go down in tire wall - the circumference should stay +/- 5% from the old one, so that the wheel and tire stays the "same". Unless you're building a monster truck, never ever put on any sort of wheels you have to recalibrate anything for.
For example; if your current wheels are 235/40/18 you can put on 235/35/19, and the circumference changes, um ... *grabs calculator* .... 0,2 inches. Not noticeable on your speedo and perfectly fine.
Old Aug 4, 2010 | 09:40 AM
MHTJustin's Avatar
MHTJustin has a spectacular aura aboutMHTJustin has a spectacular aura aboutMHTJustin has a spectacular aura aboutMHTJustin has a spectacular aura aboutMHTJustin has a spectacular aura aboutMHTJustin has a spectacular aura aboutMHTJustin has a spectacular aura aboutMHTJustin has a spectacular aura aboutMHTJustin has a spectacular aura aboutMHTJustin has a spectacular aura aboutMHTJustin has a spectacular aura about
They are correct. If you want a clear explanation on it google "wheel plus sizing" or better yet check out
Tire Tech Information - The Plus Concept
Old Aug 4, 2010 | 08:41 PM
STLG's Avatar
Thanks guys, that makes a lot of sense. Completely forgot the rubber would make a difference.
Thanks, knowing what to look for makes it easier to google it
Old Aug 4, 2010 | 08:50 PM
bonehead's Avatar
Use this handy dandy calculator when determining if your tire sizes are within acceptable rolling diameters
Tire Size Calculator - tire & wheel plus sizing
Speedo's are NOT easily recalibrated to my knowledge. And an re-alignment is not necessary if you're just changing out wheels/tires. Suspension changes (i.e springs/coilovers), on the other hand, do require one.
HRE_Wheels
Jan 24, 2012 10:40 PM
HRE_Wheels
Jan 24, 2012 09:11 PM
MoOriginal
///M
13
Aug 22, 2011 05:26 AM
spg993tt
Aug 22, 2009 07:37 PM
