What is the Best Brake Replacement for a 2007 Cayman S...
Old Jul 13, 2010 | 12:21 AM
GeoffJr@Isringhausen's Avatar
GeoffJr@Isringhausen has a reputation beyond reputeGeoffJr@Isringhausen has a reputation beyond reputeGeoffJr@Isringhausen has a reputation beyond reputeGeoffJr@Isringhausen has a reputation beyond reputeGeoffJr@Isringhausen has a reputation beyond reputeGeoffJr@Isringhausen has a reputation beyond reputeGeoffJr@Isringhausen has a reputation beyond reputeGeoffJr@Isringhausen has a reputation beyond reputeGeoffJr@Isringhausen has a reputation beyond reputeGeoffJr@Isringhausen has a reputation beyond reputeGeoffJr@Isringhausen has a reputation beyond repute
I had my Cayman on the track today and the brakes overheated during two of the sessions... It was a distraction and potentially dangerous, so it's probably time to get some new ones. Are there are any brakes that you guys would recommend over others?
Old Jul 13, 2010 | 01:03 AM
sean's Avatar
Man, you must be hammering on them. The most I've gotten is a touch of fade, but never anything serious. I actually replaced mine with the stock pads, I was told they were the best so long as you weren't turning a majority of miles on the track.
I've heard of people replacing with Giro Slotted rotors. Some people upgrade to GT3 brakes. I have no experience with any of these as I've had no issues with the car's brakes. (06 S)
Old Jul 13, 2010 | 01:12 AM
NotSoMiniC's Avatar
NotSoMiniC has a reputation beyond reputeNotSoMiniC has a reputation beyond reputeNotSoMiniC has a reputation beyond reputeNotSoMiniC has a reputation beyond reputeNotSoMiniC has a reputation beyond reputeNotSoMiniC has a reputation beyond reputeNotSoMiniC has a reputation beyond reputeNotSoMiniC has a reputation beyond reputeNotSoMiniC has a reputation beyond reputeNotSoMiniC has a reputation beyond reputeNotSoMiniC has a reputation beyond repute
try new set of pads/brake fluid?
Old Jul 13, 2010 | 01:15 AM
icruze's Avatar
icruze has a reputation beyond reputeicruze has a reputation beyond reputeicruze has a reputation beyond reputeicruze has a reputation beyond reputeicruze has a reputation beyond reputeicruze has a reputation beyond reputeicruze has a reputation beyond reputeicruze has a reputation beyond reputeicruze has a reputation beyond reputeicruze has a reputation beyond reputeicruze has a reputation beyond repute
IIRC, StopTech are the brakes being used for the Cayman Interseries races.
Old Jul 13, 2010 | 01:21 AM
IIVVX's Avatar
FIGJAM
can you get AP stoppers for the gayman? i'd go with those.
Old Jul 13, 2010 | 02:59 AM
JCay's Avatar
JCay has a reputation beyond reputeJCay has a reputation beyond reputeJCay has a reputation beyond reputeJCay has a reputation beyond reputeJCay has a reputation beyond reputeJCay has a reputation beyond reputeJCay has a reputation beyond reputeJCay has a reputation beyond reputeJCay has a reputation beyond reputeJCay has a reputation beyond reputeJCay has a reputation beyond repute
I would honestly recommend trying a high temperature brake fluid and pagid yellow pads before you spend thousands on a new set of disks. If that still doesn't do it, try replacing the master brake cylinder with the one from the GT3.
Stock brakes are really pretty good. Really.
Old Jul 13, 2010 | 11:05 AM
PJC's Avatar
PJC
PJC is a name known to allPJC is a name known to allPJC is a name known to allPJC is a name known to allPJC is a name known to allPJC is a name known to allPJC is a name known to allPJC is a name known to allPJC is a name known to allPJC is a name known to allPJC is a name known to all
I would have to agree with JCay, high temp fluid and pagid yellow pads should be all you need. The factory discs / calipers should be more than you will ever need for track day duties. I find that i have more brake than tire.
Old Jul 13, 2010 | 11:11 AM
I am really surprised the normal brakes are good, if you are willing to spend why not Brembo.
Old Jul 13, 2010 | 11:39 AM
Thanks for all the tips! I'm going to try the high temperature brake fluid and new pads first as that will probably be the cheapest route and see how that goes.
Thanks again!!!
Old Jul 13, 2010 | 11:42 AM
^ good thing.
