DIY Towing - Will Wood Hitch & Utility Trailer
Old Aug 8, 2009 | 09:42 PM
Coochas's Avatar
Coochas has a reputation beyond reputeCoochas has a reputation beyond reputeCoochas has a reputation beyond reputeCoochas has a reputation beyond reputeCoochas has a reputation beyond reputeCoochas has a reputation beyond reputeCoochas has a reputation beyond reputeCoochas has a reputation beyond reputeCoochas has a reputation beyond reputeCoochas has a reputation beyond reputeCoochas has a reputation beyond repute
My 986 has become my little track toy so I equipped it with a utility trailer as others have done. I use the trailer to carry an extra set of tires and critical tools and fluids for track days. This frees up both trunks in the Boxster which can then be used for luggage and coolers and other important items!
The trailer works great and I just added a bike rack to it so my wife will be able to bike around the countrside when she doesn't feel like doing DE driving.
I thought I would do a basic installation write up for anyone else thinking about doing it. I opted for the non-hidden dual receiver hitch from Will Wood. Will also makes a hidden hitch which goes behind the license plate which I will likely add to my 997. I believe the hitch was about $440 delivered. I think just about anyone can do this install themselves and it took me about 1.5 hours taking my time and drinking Diet Coke.
The hitch appears to be high quality and it works perfectly. All you need to do is add a trailer ball and a trailer!
Here's how it works:
1) Take off the 6mm allen bolt from the bottom of each bumperette.
2) This is what is behind the bumperette:
3) The templates supplied by Will are simply post-it notes. I scanned copies of these into my computer in case I 'screwed' up. Attach the templates as shown. I secured them with tape and then drilled right through them.
4) Drill two 13/32 holes as shown on the templates. Start by drilling with 3/16, then 9/32 to make it easier. BTW, I had no idea there was such a thing as 13/32 but I assure you it exists. Do yourself a favor and buy a bit that's meant to drill through metal otherwise you'll be there forever.
5) Bolt on the receiver plate:
6) Make sure each side is level before tightening up the bolts:
7) Notch out part of the bumperette so that it fits around the receiver bracket and reattach the bumperettes.
8) The finished product shown on/off car.
9) Add a trailer and now your Boxster is a big rig towing machine!
Old Aug 8, 2009 | 09:43 PM
Coochas's Avatar
Wiring for Utility Trailer
To wire the Boxster for use with my trailer, I used the excellent write up at Boxster Tow Hitch & Track Trailer to do the wiring for my trailer. You need to buy a 5 to 4 wire adapter as shown in my pics. This is a fairly easy DIY and involves removing some trim in the trunk and clipping into various tail light wires. I used Radioshack wire taps which worked perfectly.
Again, all the info you need is in the BombayDigital link. If you are here on Teamspeed, THANK YOU!!!!!!!
My pics are a bit clearer so here they are,……
Old Aug 13, 2009 | 06:06 PM
easyc's Avatar
easyc has much to be proud ofeasyc has much to be proud ofeasyc has much to be proud ofeasyc has much to be proud ofeasyc has much to be proud ofeasyc has much to be proud ofeasyc has much to be proud ofeasyc has much to be proud ofeasyc has much to be proud ofeasyc has much to be proud ofeasyc has much to be proud of
did the same thing myself, although I was in a pinch, and Will modified me a 987 unit... and shipped it over night... if you need a trailer hitch on your PCAR... call Will
Q8_TwinTurbo
Aug 28, 2009 07:38 AM
12
Mar 18, 2009 01:44 PM
bharrisy2k
Feb 20, 2009 11:25 PM
MoeMistry
Apr 22, 2008 01:54 PM
BSM
Mar 25, 2008 04:14 PM
