Check Engine Light x 2
Old Nov 20, 2013 | 11:34 AM
smokinghot4cars's Avatar
Originally Posted by jbtex
If you meant BMC (the red fabric filters), they are oiled like the K&N. If so, I'd replace with OEM to try and eliminate any excuse by the dealer that your oiled filter caused the problem.
Yeah BMC. Sorry. Well they still have the car and I did mentioned the CAT Sensors. Didn't get an update yesterday. The filter should not cause a problem. If I didn't tell them they probably would not have known. But I wanted to disclose all. The Akrapokic Exhaust was obvious. So whether it's any of those two aftermarket parts my thoughts are they should simply adjust whatever they think these parts may be creating a :Check Engine" light to come on. These are not radical modifications.
Old Nov 20, 2013 | 12:01 PM
Marc's Avatar
Neg Rep Zen Master
Its not the air filter the pre cat sensors have issues on this gen of car, I had an aftermarket Tubi Race on mine and it occurred and it was the pre cat O2 sensors.
Old Nov 20, 2013 | 03:08 PM
jbtex's Avatar
jbtex is an unknown quantity at this point
OK...but it is an oiled filter and there have been instances of over-oiled filters causing MAF problems...not that that is what your codes are telling you though. Hope they get it fixed.
Old Nov 22, 2013 | 06:51 PM
So the dealer had my car all week. The temp has been wildly fluctuating between high and low very quickly. So they are going to change the thermostat and housing. Hopefully that resolves this two plus week "Check Engine" light issue. Car will will be there until at least Tuesday or Wednesday of next week. Meanwhile the Cayenne is a nice to get use to ride.
HRE_Wheels
May 27, 2014 07:01 PM
HKFEVER
Oct 30, 2012 11:54 AM
RufMD
29
Nov 15, 2009 09:34 PM
