Torque Solution GT1 Engine Coolant Pipe Fix..
Old Jun 4, 2011 | 05:52 PM
Mike@AwdMotorsports's Avatar
Mike@AwdMotorsports You are a Teamspeed member that Rocks and Rolls!Mike@AwdMotorsports You are a Teamspeed member that Rocks and Rolls!Mike@AwdMotorsports You are a Teamspeed member that Rocks and Rolls!Mike@AwdMotorsports You are a Teamspeed member that Rocks and Rolls!Mike@AwdMotorsports You are a Teamspeed member that Rocks and Rolls!Mike@AwdMotorsports You are a Teamspeed member that Rocks and Rolls!Mike@AwdMotorsports You are a Teamspeed member that Rocks and Rolls!Mike@AwdMotorsports You are a Teamspeed member that Rocks and Rolls!Mike@AwdMotorsports You are a Teamspeed member that Rocks and Rolls!Mike@AwdMotorsports You are a Teamspeed member that Rocks and Rolls!Mike@AwdMotorsports You are a Teamspeed member that Rocks and Rolls!
Torque Solution has brought to you an 8pc Coolant Pipe Repair Kit for all Porsche Gt1 Engines with Press fit and Glued coolant pipes.. These will fix the issue that plagues the Gt1 engine of water pipe failures resulting in coolant dumping all over the engine bay and possibly on to the rear tires causing you to lose control of the car. This issue can ruin a good track day weekend or even worse cause you to have an accident on the street or on the track.. If you have your engine out of the car for any reason thats the best time to do the repair.. This will require the engine to be removed and the fittings welded in place.. Giving you peace of mind knowing its done right with the weld on fittings..
195.00 Shipped
erazer72
Apr 15, 2014 05:59 PM
ECS Tuning - Porsche
May 2, 2013 01:55 PM
Dan@SharkWerks
Feb 28, 2013 08:14 PM
Mike@AwdMotorsports
Jun 7, 2011 08:56 AM
EMart
Jan 9, 2011 11:37 AM
