:: ECS Tuning :: Cayenne (03-06) V8 Coolant Pipe Repair Kit
Old Jul 20, 2012 | 02:56 PM
ECS Tuning - Porsche's Avatar
Porsche recognized that the early Cayenne V8 suffered a design flaw in the plastic coolant pipes. The plastic became brittle with prolonged exposure to the heat of an engine bay, and will inevitably fail. Seeing their failure, Porsche developed a redesigned coolant pipe, crafted in aluminum. The new design replaces the plastic version with Aluminum to prevent leaks, cracks, or other failures, and withstand the test of time. ECS Tuning brings you this comprehensive 21 piece repair kit to ensure you won't be left on the side of the road. The kit includes everything needed for a smooth installation and peace of mind.
It is common knowledge among 955 Cayenne S, and Turbo owners, that the factory installed coolant pipes will eventually fail. This is not a matter of if it will happen, it is a matter of when it will happen. Save yourself the frustration of failure, and replace your pipes proactively. For more information, or to get your kit today
, CLICK HERE !!
Old Aug 7, 2012 | 11:28 AM
For DIY instructions CLICK HERE
Old Feb 1, 2013 | 11:06 AM
Every thing you need to upgrade your Coolant Pipes
Click here for more information.
Old May 2, 2013 | 01:55 PM
Chasing a mystery coolant leak? If your 2003-2006 Cayenne is losing coolant, odds are you can trace it to the original plastic coolant pipes located beneath the intake manifold.
Do it right; do it once, and eliminate this annoying problem, once and for all. Online tutorial!
Click Here for more information
Aug 7, 2015 11:28 AM
erazer72
Apr 15, 2014 05:59 PM
Mike@AwdMotorsports
Jun 7, 2011 08:56 AM
Mike@AwdMotorsports
Jun 4, 2011 05:52 PM
EMart
Jan 9, 2011 11:37 AM
