F10 going for as clean as possible
Old Feb 19, 2012 | 03:10 AM
  #21
shawnsheridan's Avatar
shawnsheridan is an unknown quantity at this point
Nice ride, although I am a bit biased.
What brand and size wheel spacers, front & rear, did you go with?
Originally Posted by TRAKCAR
I'd go with the same exact wheel design as we have now just 20" the sport package 7 series have them.
If I was going with 20", I'd go with the forged F10 M5 343M wheels, although I think a smaller tire size than the M5 tire would be needed.
Originally Posted by blissat9k
Yes, however I believe the new 7 series takes a low offset rear where the F10 5 series is mid +30 offset all the way around.
The offsets on the F10 and F01 by width are:
F10 - 19" or 20"
8.5" ET33
9" ET44
F01 - 19" or 20"
8.5" ET25
9.5" ET39
10" ET41
Old Feb 19, 2012 | 12:04 PM
  #22
TRAKCAR's Avatar
TRAKCAR has a reputation beyond reputeTRAKCAR has a reputation beyond reputeTRAKCAR has a reputation beyond reputeTRAKCAR has a reputation beyond reputeTRAKCAR has a reputation beyond reputeTRAKCAR has a reputation beyond reputeTRAKCAR has a reputation beyond reputeTRAKCAR has a reputation beyond reputeTRAKCAR has a reputation beyond reputeTRAKCAR has a reputation beyond reputeTRAKCAR has a reputation beyond repute
A friend of mine did the research.
I think HR springs, spacers 15 and 10 mm with oem size Michelin supper sport non run flats.
Old Feb 19, 2012 | 01:53 PM
  #23
Thanks. Do you know if it's 15mm on the Front, and 10mm on the Rear, or vice versa? Also, do you know the brand?
Old Feb 19, 2012 | 02:22 PM
  #24
TRAKCAR's Avatar
H&R spacers with longer bolts. 15f and 10r not 100% sure.
Where arte you located, maybe my friend can do it for you. I will ask him anyway
Old Feb 19, 2012 | 03:55 PM
  #25
Thanks for the update and offer, and I could sure use the help, but I'm a long ways from Florida, as I'm in Houston, TX.
You have been helpful though, and I appreciate it. I'm having difficulty finding people who have installed spacers on F10 OEM wheels. One person I know went 12mm all around and said it was flush, and another went with 5mm up front and 15mm in the rear, and of course his was flush too. If you are in fact 15mm up front and 10mm in the rear as you believe you are, then the range is a wide 5mm - 15mm up front, and a tighter 10mm - 15mm in the rear.
I like the way yours looks in the picture, so if you are able to confirm your setup, I'd greatly appreciate it. Also, are the H&R Extended Lug Bolts black or silver?
Old Feb 20, 2012 | 09:34 PM
  #26
M3EvoBR's Avatar
M3EvoBR will become famous soon enoughM3EvoBR will become famous soon enoughM3EvoBR will become famous soon enoughM3EvoBR will become famous soon enoughM3EvoBR will become famous soon enoughM3EvoBR will become famous soon enoughM3EvoBR will become famous soon enoughM3EvoBR will become famous soon enoughM3EvoBR will become famous soon enough
That's correct, Thanks Peter. We used H&R springs, and spacers. I can source them out to you.
The car looked great for the little work we did.
let me know if you need any help.
tks.
Old Feb 20, 2012 | 11:11 PM
  #27
tks.
Can you confirm it was 15mm up front and 10mm in the back?
mechamegalodon
The Team Speed Shooting Range
21
Nov 11, 2011 06:39 PM
attic2zoo
21
May 7, 2010 03:13 AM
frissen
General BMW | Mini
Sep 1, 2009 08:57 PM
fabryce@gmgracing
Automobiles
Feb 26, 2009 06:47 PM
///M
Feb 19, 2009 05:44 PM
