Best Way To Clean The Engine Bay?
Old Mar 8, 2010 | 05:15 PM
vtgts300kw's Avatar
Its covered in dust.
Thank-you.
Old Mar 8, 2010 | 05:18 PM
strebo's Avatar
Nutcrusher
Remove the dust.
You're welcome.
Old Mar 8, 2010 | 05:27 PM
jox's Avatar
jox
Old Mar 8, 2010 | 05:36 PM
vtgts300kw's Avatar
I dunno if you are joking, and thats the obvious answer, but will using mass amounts of water cause it to get anyway it shouldn't?
Old Mar 8, 2010 | 05:49 PM
jox's Avatar
jox
It's fine. Just try not to spray directly onto electric parts (ie the generator/fuse box etc). And I usually let the engine run a few minutes after, to dry it all out.
But if the engine is mounted upside down in your part of the world, perhaps you should get a lift to gain access . . .
Old Mar 8, 2010 | 08:45 PM
crazy1323's Avatar
crazy1323 has a reputation beyond reputecrazy1323 has a reputation beyond reputecrazy1323 has a reputation beyond reputecrazy1323 has a reputation beyond reputecrazy1323 has a reputation beyond reputecrazy1323 has a reputation beyond reputecrazy1323 has a reputation beyond reputecrazy1323 has a reputation beyond reputecrazy1323 has a reputation beyond reputecrazy1323 has a reputation beyond reputecrazy1323 has a reputation beyond repute
AVOID IGNITION COILS!!!! In the B6/B7 world people have ruined many ignition coils. People wash the engine bay and spray the coils and ruin them.
I simply spray the engine down with P21 Total Auto Wash, agitate with a brush, and wipe with microfiber.
Old Mar 8, 2010 | 08:48 PM
Barrister's Avatar
I had my 360 detailed just before I had my motorcycle accident.
The electronic clutch sensor got wet and corroded.
When I drove the car, the clutch was destroyed as a result.
There are some engine parts that don't like water.
Old Mar 8, 2010 | 09:07 PM
quickZohsix's Avatar
What kind of car
Steps I always use with no problems (obviously Dana had some I never had)
Put a plastic bag over battery, dizzy, fuse box ect just to be careful.
water down the engine, avoid electrical areas obviously. spray on some simple green, use a brush to aditate dirty areas, hose off. start engine, ejoy a clean engine bay
This is just advice and if you destroy your engine, Im not responsible
BUT I have done the above many times with no problems
Old Mar 8, 2010 | 09:20 PM
Barrister's Avatar
That's a nice ATTEMPT at a disclaimer.
Come to me for help next time.
Old Mar 8, 2010 | 09:35 PM
lol I knew that was coming. More of a heads up. wanna help me out? actually never mind, I feel like I should save a favor for something better than this lol
