LED foglight city bulbs
Old Apr 24, 2009 | 04:11 PM
porsches4ed's Avatar
porsches4ed has a reputation beyond reputeporsches4ed has a reputation beyond reputeporsches4ed has a reputation beyond reputeporsches4ed has a reputation beyond reputeporsches4ed has a reputation beyond reputeporsches4ed has a reputation beyond reputeporsches4ed has a reputation beyond reputeporsches4ed has a reputation beyond reputeporsches4ed has a reputation beyond reputeporsches4ed has a reputation beyond reputeporsches4ed has a reputation beyond repute
cost: $4.95 each bulb
part: BA9s-WHP6-12V 6 High Power LED Bulb
difficulty: 1-5 is 1 super easy
tools needed:
phillips screwdriver
purchased from SUPER BRIGHT LEDS home (not a forum sponsor)
I purchased LED parking light bulbs which are in the foglight housing...
here you can see the difference between the two halogen and LED, they have built in resistors so there is no bulb out warning...
here is the package with the part #'s old bulbs are in it now...
first remove the foglight shroud...
remove the three screws...
pull out the old bulb by twisting it off and put the new LED in by pushing it in then twisting, the pins do mot match up perfect they are off. It will still hold the bulb in place fine...
here it is on, so bright matches xenons perfect, its much brighter than the factory halogen bulb...
it will fit in you have to turn it at an angle then slide it in...
push it into the housing twist again and thats it, now turn on the parking lights...
here is the halogen...
now side by side...
and both on... (HID foglights are off)
and now all lights on...
cant match xenons better than LEDs.
rmani
Mar 18, 2011 01:21 PM
Yacht Lights
Feb 25, 2011 09:48 PM
porsches4ed
Apr 24, 2009 04:49 PM
porsches4ed
Apr 24, 2009 04:08 PM
LaneS@macarbon.com
11
Aug 31, 2008 06:46 AM
