2006 Bentley CGT hot-start and wiper skipping problem
Old Apr 19, 2009 | 12:43 PM
unpollo2's Avatar
unpollo2 is an unknown quantity at this point
Any other users experience/fix these problems and how:
1- Driver side wiper blade is smooth until about 5 minutes of constant rain. Then it begins to chatter and skip both on the upswing and down... but only at the slow wiper speed, not the fast wiper speed. I have had them changed 2 times at dealership and thoroughly cleaned windshield with lighter fluid, clay bar, etc etc. If I spray the windshield with the washer jets while raining it smooths out for about 5 minutes then becomes skipping again.
2- Hot start issue is tricky. After driving for 15+ minutes when the engine is nice and hot (200 temp) I will park it (sunny day, cold garage, night time outside, doesn't matter where). If I attempt to start the engine again within 30min to 1.5 hours, randomly (about 20% of the time) it will stutter and shake for the first 8 seconds and then smooth out. If I try and give it gas nothing happens, I have to wait for it to smooth out. If I shut the car off and then immediatly restart it it is smooth as silk. I have had the tech run diagnostics and it isn't engine misfires as no codes are stored. There is a funny clunking noise that the tech identified as "heater valve opening closing on firewall" but checked it and said it was doing it's job. Cold starts are perfect. I have been through 10 different tanks of gas from different vendors as well as 2 Chevron Techron additives... no change. Always 93 octane. Spark plugs changed and distributer caps upgraded to new model. No change. Tech did find a loose grounding wire from the engine which he cleaned and tightened and the issue has been 50% of original description but still exists.
Old Apr 19, 2009 | 01:51 PM
Try Rain-X to solve the first problem. Otherwise, it sounds like you're trying to run the wipers when there isn't enough water on the windshield.
As for the hot-start issue, it could be a lot of things. Perhaps air in the cooling system are keeping it from cooling down properly? Might want to get your radiator cap checked or add some coolant.
Auto Concierge
Jun 2, 2014 01:45 AM
Acealloywheel
Sep 10, 2011 02:54 PM
unpollo2
Oct 28, 2009 10:41 PM
EVS Motors Inc.
Automobiles
Aug 27, 2008 11:02 PM
Stryke
Automobiles
Jul 11, 2008 03:24 PM
