Get an ultimate track setup with Agency Power Rear Control Arms at CARiD!
Old Mar 28, 2017 | 08:55 AM
carid's Avatar
Former Vendor
carid is infamous around these parts
Suspension setup is extremely important for optimal handling of any vehicle. When its lowered, it t changes the suspension geometry which requires an alignment. The rear camber and toe adjustments are a key element in the way your vehicle will handle. Agency Power has developed strong adjustable rear control arms to help you with a suspension adjustment of your Porsche.
Machined from 6061 CNC aluminum for reduced weight and anodized black for long lasting great looks they provide great performance for a long time. To improve strength and rigidity Agency Power has increased the thickness where the shock and sway bar link mount. The control arms are designed as complete OEM replacements – they remove the factory rubber bushings with solid mounts to provide a more responsive feel. With these control arms you are able to get more negative camber or positive camber as you need. They are sold 2 per pack and feature the Agency Power logo.
Agency Power® Rear Adjustable Control Arms
Give your Porsche a proper adjustments with Agency Power Rear Control Arms at CARiD!
carid
Feb 11, 2015 06:02 AM
Chris Green@USP
Dec 17, 2010 09:39 AM
Chris Green@USP
Sep 21, 2010 04:06 PM
Chris Green@USP
Sep 20, 2010 05:26 PM
