HPF Stage 2 Turbo kit for BMW E46 M3 & Supporting parts
Old Sep 24, 2014 | 06:12 AM
Leonel_hpf_m3's Avatar
Leonel_hpf_m3 is an unknown quantity at this point
Car is being parted out.
This thread is for the HPF stage 2 Turbo kit
Relatively young kit, has only 8k miles on it
All that will be included is the following
Plug-n-play AEM V1 stand alone engine management system
Six Drop in 750cc "high impedance" injectors (no fuel rail mods required)
Auxiliary fuel pump w/filter that turns on at 3psi w/electronic connector
Ceramic coated, CNC machined 1018 mild steel turbo manifold
Precision 6766 turbo w/.81 AR
Precision 46MM wastegate / open dump
Stainless steel downpipe
Powdercoated Intake manifold
Intake manifold couplers w/clamps
Twin HKS blow off valves
Polished 4" thick, 24" wide core bar-n-plate intercooler
Powdercoated aluminum intercooler piping
Powdercoated aluminum intake piping
5 ply silicon couplers
T-bolt intercooler clamps
KN intake filter with clamp
Steering column mounted dual pod
AEM UEGO wide-band gauge
AEM boost gauge
Race fuel switch w/LED
Knock siren
Harnesses for fuel pump and oil pump assemblies
Harnesses for gauges, race fuel switch, LED and knock siren
Oil pump with mounting bracket and electronic connector
One piece oil pump feed and return lines
One piece turbo oil feed and one piece head to pan oil line
Multiple vacuum lines w/quick disconnects
AEM 3.5bar map sensor
Boost control solenoid
Intake air temp sensor
HPF Engine Mounts
Fittings and block off plates
HPF Underbrace/Skid plate
All Methanol components
Methanol switch
HPF install manual
Asking $11,500 Obo
Extra parts ALSO For Sale:
- Tubi Rumore exhaust section 2 and 3 for: $750/$1750 or $2500
- Saad Racing Diff Brace: $300 (Sale Pending)
- Spare HPF/Bosch 7500cc Injectors: $450
- *New* StopTech Aero 345 x 32mm REAR Disc + Hats: $850
- Used - Conti DWS 285-30-19 tires 7/10ths (Sold)
- Used - LingLong L688 tires 245-35-19s 7/10ths; $200
- Used - Toyo Proxes 4 tires 245-35-19s 7/10ths ; $300
- New - Nitto Invo tires 245-35-19s ; $300
* spare black powder coated turbo intake pipe
* means it can be included with the Turbo kit *
**** PREFER A LOCAL BUYER IN TEXAS BUT CAN AND WILL SHIP AT BUYERS EXPENSE *******
Old Sep 24, 2014 | 06:16 AM
More Pics
Old Oct 1, 2014 | 08:03 AM
Thank you all for your support and consideration, Stage 1 of my HPF Turbo kit has SOLD.
2006 Blk/Blk SMG M3, Exhaust, brakes, tires, steering wheel, Forgestar F14 19x8.5 wheels still available
Abo Al3ol
Oct 3, 2012 12:35 PM
speed12
///M
Nov 13, 2011 02:31 PM
jaykla
May 10, 2010 07:33 PM
sharky
Mar 11, 2010 06:00 AM
MiniD
24
Feb 2, 2009 01:51 AM
