Mixing Tire Types - Front and Rear
Old Jul 19, 2012 | 05:38 PM
dallascajun's Avatar
dallascajun You are a Teamspeed member that Rocks!dallascajun You are a Teamspeed member that Rocks!dallascajun You are a Teamspeed member that Rocks!dallascajun You are a Teamspeed member that Rocks!dallascajun You are a Teamspeed member that Rocks!dallascajun You are a Teamspeed member that Rocks!dallascajun You are a Teamspeed member that Rocks!dallascajun You are a Teamspeed member that Rocks!dallascajun You are a Teamspeed member that Rocks!dallascajun You are a Teamspeed member that Rocks!dallascajun You are a Teamspeed member that Rocks!
I've read through some previous threads on this, and just went through my own little episode, so thought I'd post my experience and some of the knowledge gained:
I had some new wheels installed on my car last week. Since the rears were gone but fronts still OK, I decided to just put some Hankook V12s on the rear and leave the PZs on the front, and then replace all 4 the next time tires were needed.
So after getting the car back, it took about a 1/2 mile to figure out something was wrong. At first I was worried the center lock nuts weren't torqued enough, but then realized I would feel the wheels shaking violently. It then occurred to me that the new rear tires were the cause.
When I got home I noticed that the tire pressure across the corners was 5-7 lbs high, and I thought (hoped) that might be the problem, so I brought them all back to 'normal' pressure. WRONG...that made it WORSE. More to come on that in a bit.
This morning I was driving on one of the Dallas highways and got to the big left hand turn that's a slight double-radius turn that catches many people off-guard and requires some constant steering input, usually at 70mph+. I swore my car was going to hit a wall. The initial steering input gave me quick response, but then there was a 1/2 second lag when the rear end would start it's weight shift, which led to oversteer, and my car almost facing the wall. It took fair amount of small corrections back and forth to get my car where it felt stable, because this motion caused a rather strong oscillation of movement from left to right.
So that episode led me straight to Boardwalk, and I mean STRAIGHT there.
After talking to John Gladwell (Service Tech extraordinaire), several things became quite clear:
1) The Hankook V12 has a MUCH softer sidewall that the Pirelli's, or other factory tire. It just doesn't take the weight shifts very well. He said that tire is decent for people that are looking for a softer, cruising ride and works ok with 996s due to the reduced power in those cars.
2) The P-Zeros up front have much better grip, so steering input through the front PZ would be sharper than the Hankooks can handle. Given the Hankooks weaker grip & sidewall, they would just amplify the difference in grip and the rear would be relatively 'floaty'. This is one of the most basic reasons as to why the front/rear tires should match: equal grip/sidewall limits.
3) After getting my car back with the new wheels, I noticed the air pressure was 7-8lbs high all around, with the TPMS readout verifying. So, I brought everything back to 'normal' when I reduced the air pressure. It turns out that reducing air pressure makes it worse because that change basically makes the sidewalls that much 'softer'. He said it really doesn't affect the contact patch at all, and has negative impacts on tire wear.
4) I knew my Panamera had 2 TPMS settings for Loads (Full/Half), but didn't realize the 997 also had this. When we changed the TPMS settings in the computer to Full, it now showed my tires as 5-7 lbs LOW. Basically, these two settings affect the warning systems in the car to tell you when to add air. By adding air pressure to the tires, it will 'strengthen' the sidewall for this need.
Next Step: Michelin Pilot Super Sports going on tomorrow/saturday on all 4 corners (as soon as BW receives them). I considered just putting 2 more PZs on the rears, but closer inspection of the fronts told us that they really only have a few 1000 miles left on them, and the PZs are known to degrade quickly when they get close to the end. The MPSS has a better tread wear rating, better grip, makes less road noise and maintains it's tread better over the last 1/4 of tread use than the PZ (per John).
Lessons Learned:
1) The Hankook V12 isn't a bad tire across the board, but not the best for this application (305/30). Of course, Any 305/30 (or similar size) is going to be on a sports car, so not sure why such a size is manufactured if it's not quite appropriate for similar applications.
2) Do NOT mix tire types from front to rear due to the relative difference in grip/sidewall strength. After discussing it with John and thinking it through, the simple logic makes a ton of sense.
3) The higher end of recommended tire pressure will not have negative impact on daily (spirited) driving, but will help reduce tread wear.
Old Jul 19, 2012 | 05:48 PM
Sorry you had to learn this the hard way. I agree the Hankooks are decent tires but for much lower performance cars. Also, good call on the Super Sports. You'll love them!
Old Jul 19, 2012 | 07:42 PM
Thanks. I'm trying to maintain the perspective that it's much better learning this lesson with an impact to my wallet as opposed to an impact with a wall.
Sent from my HTC One X using teamspeed
Old Jul 19, 2012 | 07:59 PM
STOPPIE's Avatar
Teamspeed's Howitzer
I'm confused. Did you own a Porsche or did you just graduated from High School? Who the HELL does that??
Cheapskate!
Glad nothing bad happened buddy!
Old Jul 19, 2012 | 08:16 PM
Originally Posted by STOPPIE
Cheapskate!
Yeah, there's probably a little bit of that to get me in this situation...
Why does trying to save a buck always seem to cost you 4 more? Probably the same reason why the cover up is always so much worse than the original crime.
Old Jul 19, 2012 | 08:29 PM
Maitre_Absolut's Avatar
Maitre_Absolut You are a Teamspeed member that Rocks!Maitre_Absolut You are a Teamspeed member that Rocks!Maitre_Absolut You are a Teamspeed member that Rocks!Maitre_Absolut You are a Teamspeed member that Rocks!Maitre_Absolut You are a Teamspeed member that Rocks!Maitre_Absolut You are a Teamspeed member that Rocks!Maitre_Absolut You are a Teamspeed member that Rocks!Maitre_Absolut You are a Teamspeed member that Rocks!Maitre_Absolut You are a Teamspeed member that Rocks!Maitre_Absolut You are a Teamspeed member that Rocks!Maitre_Absolut You are a Teamspeed member that Rocks!
I also run super sports, you'll love them
Old Jul 20, 2012 | 01:01 AM
BLACKBULL's Avatar
BLACKBULL has a reputation beyond reputeBLACKBULL has a reputation beyond reputeBLACKBULL has a reputation beyond reputeBLACKBULL has a reputation beyond reputeBLACKBULL has a reputation beyond reputeBLACKBULL has a reputation beyond reputeBLACKBULL has a reputation beyond reputeBLACKBULL has a reputation beyond reputeBLACKBULL has a reputation beyond reputeBLACKBULL has a reputation beyond reputeBLACKBULL has a reputation beyond repute
If you don't believe it ask Joe Paterno's family!!!
Old Jul 20, 2012 | 09:51 AM
Marc's Avatar
Neg Rep Zen Master
... really...
Old Jul 20, 2012 | 01:48 PM
STOPPIE's Avatar
My line of thinking- you spent ALL this money on a HIGHLY engineered car. Give the Engineers some credit that they know better than you as to why they selected the tires they did.
This is a classic case. live and learn mate.
Blue4reF1
9
Mar 25, 2011 06:33 PM
Aug 7, 2010 05:30 PM
Jack628
17
Jun 16, 2009 09:31 AM
