Running 2010 Turbo with DFI on 95 RON instead of 98 RON Pump gas....
Old Sep 24, 2009 | 07:50 AM
0-60Motorsports's Avatar
Question Running 2010 Turbo with DFI on 95 RON instead of 98 RON Pump gas....
Hey Guys,
Just wanted to get some feedback from people on TS about running The 2010 Turbo on 95RON as the PUMP GAS in BAHRAIN is 95. Like UAE, KUWAIT, QATAR we do not have 98 available on PUMP.
Maybe mixing Race gas with 95 will achieve 98 or near good enough?
Pros and Cons?
Oh Grey TT what are you using? MUMTAZ or VP?
Old Sep 24, 2009 | 10:49 AM
sean's Avatar
98 RON = 93 AKI
In California we only get 91 AKI, which is 95 RON. So we're in the same situation. Porsche sells a TON of cars here and they run fine (they're designed to run down to 90 octane AKI). We can get 100 from the pump at 76 stations; I mix a 4 gallons in my Cayman to bring the octane up to 93 when I'm running hard and there is a noticeable jump in power.
You won't damage it on 95, but you will get more power on 98.
Old Sep 24, 2009 | 01:08 PM
PMac's Avatar
PMac has a reputation beyond reputePMac has a reputation beyond reputePMac has a reputation beyond reputePMac has a reputation beyond reputePMac has a reputation beyond reputePMac has a reputation beyond reputePMac has a reputation beyond reputePMac has a reputation beyond reputePMac has a reputation beyond reputePMac has a reputation beyond reputePMac has a reputation beyond repute
As mentioned, you won't damage the engine, but you will lose some power, particularly with the heat. Adding in some race gas will definitely help. If you're running any extra boost, I'd upgrade that statement from 'desirable' to 'essential'.
Old Sep 24, 2009 | 03:49 PM
The car will be run stock fellas, So how much of C16 (VP) should be added to 95 Ron to get it up to 98 Ron?
Old Sep 24, 2009 | 04:24 PM
sean's Avatar
C16 is leaded; don't run that, you'll clog the cats. Run unleaded. I run about 1/4th 100 to bring it up to 93.
Old Sep 24, 2009 | 04:35 PM
OK can you tell me which is the recommended unleaded fuel to add from the VP range?
Old Sep 24, 2009 | 04:53 PM
msindi's Avatar
msindi has a reputation beyond reputemsindi has a reputation beyond reputemsindi has a reputation beyond reputemsindi has a reputation beyond reputemsindi has a reputation beyond reputemsindi has a reputation beyond reputemsindi has a reputation beyond reputemsindi has a reputation beyond reputemsindi has a reputation beyond reputemsindi has a reputation beyond reputemsindi has a reputation beyond repute
My understanding is Gulf Spec Porsches can run fine on lower octane...
I think they FINALLY have 98 in Saudi (ironic given it is the largest producer of crude in the world)
Old Sep 24, 2009 | 04:57 PM
No 98 in KSA as far as i know. They got the same on pump as Bahrain 95 RON. Bahrain has 98 RON but only for export.
Old Sep 24, 2009 | 09:17 PM
NinjaBoy's Avatar
NinjaBoy is a glorious beacon of lightNinjaBoy is a glorious beacon of lightNinjaBoy is a glorious beacon of lightNinjaBoy is a glorious beacon of lightNinjaBoy is a glorious beacon of lightNinjaBoy is a glorious beacon of lightNinjaBoy is a glorious beacon of lightNinjaBoy is a glorious beacon of lightNinjaBoy is a glorious beacon of lightNinjaBoy is a glorious beacon of lightNinjaBoy is a glorious beacon of light
Get 103 or 109 from the VP range. Forget about the C14, C16, C23. They are leaded and you dont need that. VP103 and 109 are unleaded and are great ...
Dan@SharkWerks
Dec 22, 2011 07:36 PM
Barrister
Pit-Stop
Feb 15, 2010 06:33 AM
Dan@SharkWerks
Jan 6, 2010 08:50 PM
wyk1982
Jan 5, 2010 02:00 PM
Jack628
Jun 16, 2009 02:33 PM
