Engine Out
Old Feb 2, 2009 | 01:07 PM
Pablo Escobar's Avatar
Great pictures! Keep coming if you have a couple minutes to spare...
Old Feb 2, 2009 | 01:35 PM
tonyh's Avatar
tonyh has a spectacular aura abouttonyh has a spectacular aura abouttonyh has a spectacular aura abouttonyh has a spectacular aura abouttonyh has a spectacular aura abouttonyh has a spectacular aura abouttonyh has a spectacular aura abouttonyh has a spectacular aura abouttonyh has a spectacular aura abouttonyh has a spectacular aura abouttonyh has a spectacular aura about
hey carb
why did the engine need to come out ?
Old Feb 2, 2009 | 01:47 PM
Barrister's Avatar
Very nice! Thanks for the very cool and rare view of that great engine!
Old Feb 2, 2009 | 01:56 PM
Zorro's Avatar
Originally Posted by Alzilla
Also, what's the dealio with the 16 velocity stacks? I noticed that there are two different shapes, presumably one for each cylinder. Can they be activated at different RPM ranges for more torque or more horsepower? I've never seen an engine that has done that before...
Twice the V-Stacks for twice the power, baby!
Actually, only 8 are velocity stacks. The inside ones appear to be going into the opposite bank plenum ... most likely for improved flow, pressure and /or balance. I'm not engineer, so I may be completely off, but I know equalizing cylinder/banks intake pressure can have a positive effect.
Old Feb 2, 2009 | 02:58 PM
I hadn't noticed that the smaller ones were going across to the other intake plenum. I think cstroked was on the right track about it possibly helping with swirl and possibly tumble as well. I'm not sure if there is necessarily a need for balance as both intake plenums appear to be the same size. Now I'm starting to think the smaller runners that are much longer as a result of crossing to the opposite plenum are what helps make some low end torque. Waiting for McCoy/Luigi to verify...
Old Feb 2, 2009 | 04:02 PM
Zorro's Avatar
looks like we had it right
The intake manifold features straight inlet tracts to the two central plenums that, in turn, have trumpets individually cast at the top of the tracts for each cylinder, to ensure optimum air flow to the cylinder heads. A rotating drum - actuated pneumatically by the engine control unit - compensates for variations in the effective volume inside the two plenums to optimise the intake resonance characteristics and therefore maximise the torque curve throughout the rev range.
Old Feb 2, 2009 | 04:38 PM
McCoy's Avatar
McCoy has a reputation beyond reputeMcCoy has a reputation beyond reputeMcCoy has a reputation beyond reputeMcCoy has a reputation beyond reputeMcCoy has a reputation beyond reputeMcCoy has a reputation beyond reputeMcCoy has a reputation beyond reputeMcCoy has a reputation beyond reputeMcCoy has a reputation beyond reputeMcCoy has a reputation beyond reputeMcCoy has a reputation beyond repute
The engine is from a 360 Modena F1 Challenge - it's undergoing a full rebuild.
Old Feb 2, 2009 | 05:25 PM
Nice! Thanks for doing the research. You've got rep.
Old Feb 2, 2009 | 05:33 PM
cabaynes's Avatar
cabaynes has a reputation beyond reputecabaynes has a reputation beyond reputecabaynes has a reputation beyond reputecabaynes has a reputation beyond reputecabaynes has a reputation beyond reputecabaynes has a reputation beyond reputecabaynes has a reputation beyond reputecabaynes has a reputation beyond reputecabaynes has a reputation beyond reputecabaynes has a reputation beyond reputecabaynes has a reputation beyond repute
Just saw this on FChat too... nice pictures!
Old Feb 2, 2009 | 09:26 PM
86blackwidow's Avatar
Very cool pictures.
