Shotgun for home defense + skeet/trap?
Old Apr 7, 2009 | 03:18 PM
Ara's Avatar
Ara
I use a Benelli M4 for home defense and a Benelli Legacy for hunting/skeet. If I had to pick just one, it would be the M4.
Old Apr 7, 2009 | 03:21 PM
jamie's Avatar
Buy the best and most reliable on the planet: Remington 870 Wingmaster of one of it variants. I have thousands and thousands of rounds through mine with nary a hint of trouble.
Old Apr 7, 2009 | 03:39 PM
Andrew's Avatar
Andrew has a reputation beyond reputeAndrew has a reputation beyond reputeAndrew has a reputation beyond reputeAndrew has a reputation beyond reputeAndrew has a reputation beyond reputeAndrew has a reputation beyond reputeAndrew has a reputation beyond reputeAndrew has a reputation beyond reputeAndrew has a reputation beyond reputeAndrew has a reputation beyond reputeAndrew has a reputation beyond repute
Would it be possible to stick with the same barrel (shorter), but just use a tighter choke for trap (like a full choke)? Or does the barrel length actually have a large impact other than affecting the inertia when following a target?
Old Apr 7, 2009 | 03:59 PM
eshaun's Avatar
The legality of racking is the same as holding it within hearing or sight of your threat, let alone pointing at or even shooting someone in cali (threatening with deadly weapon and all that)...a not so smart buddy of mine did that to scare someone away and ended up with a pile of paperwork and legal problems...what are the laws like in NC? Let us know what u end up picking up...
Old Apr 7, 2009 | 04:02 PM
Overtaker's Avatar
Originally Posted by Andrew
Cool. My girlfriend resists having a gun in the house, because she associates owning a gun with a willingness to shoot someone. Logically, however, if I am ever actually forced to use one, it meant we were in a situation that required it. If we're in the same situation and are defenseless, what might happen?
She's also under the impression that guns are inherently unsafe and can go off randomly. Time to educate, I guess .
I'm sorry to hear about your unfortunate situation. Have her place a firearm on the table and watch what it does from the safety of another room.
North Carolina has a castle doctrine. They can kill any intruder if they feel that the intruder will kill, inflict serious bodily harm, or commit a felony within their homes.
§ 14‑51.1. Use of deadly physical force against an intruder.
(a) A lawful occupant within a home or other place of residence is justified in using any degree of force that the occupant reasonably believes is necessary, including deadly force, against an intruder to prevent a forcible entry into the home or residence or to terminate the intruder's unlawful entry (i) if the occupant reasonably apprehends that the intruder may kill or inflict serious bodily harm to the occupant or others in the home or residence, or (ii) if the occupant reasonably believes that the intruder intends to commit a felony in the home or residence.
(b) A lawful occupant within a home or other place of residence does not have a duty to retreat from an intruder in the circumstances described in this section.
(c) This section is not intended to repeal, expand, or limit any other defense that may exist under the common law. (1993 (Reg. Sess., 1994), c. 673, s. 1.)
Old Apr 7, 2009 | 04:18 PM
stuka's Avatar
Teamspeed's Mr. Spock
CA has castle doctrine.
If there is an intruder in your house and your life is being threatened, you do not need to retreat.
But that doesn't mean you can rack your gun just to scare off the Jehovah's witness people at your door.
Old Apr 7, 2009 | 04:46 PM
Ag Surfer's Avatar
Ag Surfer has a reputation beyond reputeAg Surfer has a reputation beyond reputeAg Surfer has a reputation beyond reputeAg Surfer has a reputation beyond reputeAg Surfer has a reputation beyond reputeAg Surfer has a reputation beyond reputeAg Surfer has a reputation beyond reputeAg Surfer has a reputation beyond reputeAg Surfer has a reputation beyond reputeAg Surfer has a reputation beyond reputeAg Surfer has a reputation beyond repute
Made me think... how cool would it be if your door bell was programmed to play the sound of a shotgun being racked a few seconds after the button is pushed: iChime, The “Play Anything” Musical Doorbell » The UberReview
Old Apr 7, 2009 | 06:06 PM
stuka's Avatar
Did you end up buying anything?
I know a lot of us SoCal TS'ers got the Sig 556 not too long ago.
Old Apr 7, 2009 | 07:42 PM
Ag Surfer's Avatar
I haven't yet.
Old Apr 8, 2009 | 01:15 AM
Ryan in SD's Avatar
Official TS Crybaby - Forever
Ryan in SD has a reputation beyond reputeRyan in SD has a reputation beyond reputeRyan in SD has a reputation beyond reputeRyan in SD has a reputation beyond reputeRyan in SD has a reputation beyond reputeRyan in SD has a reputation beyond reputeRyan in SD has a reputation beyond reputeRyan in SD has a reputation beyond reputeRyan in SD has a reputation beyond reputeRyan in SD has a reputation beyond reputeRyan in SD has a reputation beyond repute
Remington 870 is the way to go.
Cheap, highly modifiable and super easy to change out barrels. Good track record too. I own one as does a friend, no complaints yet.
