:: ECS Tuning :: 993 - 968 - 964 - 928 LED License Plate Light Kits!
Old Jan 29, 2015 | 03:17 PM
ECS Tuning - Porsche's Avatar
Ziza lighting is proud to introduce LED license plate bulbs for Porsche that will not throw a bulb out code. These lights are direct replacement bulbs that install in minutes, there is no need to wire up fancy resistors or hack your factory wiring to get these to work.
Simply remove your plate light assembly, and replace the factory incandescent bulb with our Ziza bulb. When installing bulbs, be sure to place the end with the large heat sink pointing upwards, this makes sure the brightest part of the LED will be shining down on your license plate.
Click Here for more information
Old Jul 16, 2015 | 01:45 PM
Upgrade your dull, yellow license plate lights with Ziza LEDs. If you're after the bright white, modern look of LEDs, your hunt is over.
Click here for more information
Old Jan 22, 2016 | 04:09 PM
Our Ziza LED license plate lights are in stock and shipping for free!
Installation is child's play - simply remove the old bulbs, and pop in the LEDs! A built-in heat sink prevents overheating and melted housings.
Jan 26, 2015 05:19 PM
ECS Tuning-Audi
Apr 19, 2013 04:12 PM
Dec 18, 2012 03:35 PM
Dec 11, 2012 12:36 PM
Oct 19, 2012 03:47 PM
