Titan Motorsports releases Modified Oil Pump for 2JZ Engines
Old May 3, 2012 | 04:15 PM
titannero's Avatar
titannero You are a Teamspeed member that Rocks and Rolls!titannero You are a Teamspeed member that Rocks and Rolls!titannero You are a Teamspeed member that Rocks and Rolls!titannero You are a Teamspeed member that Rocks and Rolls!titannero You are a Teamspeed member that Rocks and Rolls!titannero You are a Teamspeed member that Rocks and Rolls!titannero You are a Teamspeed member that Rocks and Rolls!titannero You are a Teamspeed member that Rocks and Rolls!titannero You are a Teamspeed member that Rocks and Rolls!titannero You are a Teamspeed member that Rocks and Rolls!titannero You are a Teamspeed member that Rocks and Rolls!
Titan Motorsports is proud to introduce its performance oil pump for the Toyota 2JZ engine. Titan begins with an brand new OEM Toyota Oil pump and performs a complete disassembly and inspection prior to upgrade. The factory tolerances are verified and any imperfections are deburred for precise fitment. The pressure and feed sides both receive exstensive porting to improve increased flow and to prevent cavitation. When completed with the modification the pump is pressure cleaned before being reassembled to factory specifications and painted black for improved aesthetics. No core exchange is needed for this process as all pumps start with a brand new unit that is factored into the retail price of $399.00.
Available on our website : Titan Motorsports Modified 2JZ Oil Pump
titannero
Oct 25, 2012 07:03 PM
titannero
Jun 9, 2012 12:19 PM
titannero
Jan 25, 2012 01:28 PM
HRE_Cory
///M
16
Oct 15, 2010 12:18 PM
