Anyone help with a E46 CD Changer issue?
Old Oct 22, 2009 | 07:20 PM
Gill's Avatar
Gill You are a Teamspeed member that Rocks!Gill You are a Teamspeed member that Rocks!Gill You are a Teamspeed member that Rocks!Gill You are a Teamspeed member that Rocks!Gill You are a Teamspeed member that Rocks!Gill You are a Teamspeed member that Rocks!Gill You are a Teamspeed member that Rocks!Gill You are a Teamspeed member that Rocks!Gill You are a Teamspeed member that Rocks!Gill You are a Teamspeed member that Rocks!Gill You are a Teamspeed member that Rocks!
so...
I bought a second hand E46 323Ci on the weekend with an OEM cd changer in the boot.
All was working fine until today- I inserted a CDR with music I'd just burned, turned on the ignition and I just get a constant "CD CHECK" message on the display.
I've tried taking all disks out, putting in just one original manufacturer CD (in each of the 6 slots) but I just get the same message. The display recognises when I take out the cartridge but as soon as it goes back in I get the "CD CHECK" message constantly
I've also tried removing the fuses to the audio system for 20 mins but to no avail.
Anyone experienced anything similar?
TIA
Old Dec 31, 2009 | 10:39 PM
thiru's Avatar
thiru is infamous around these partsthiru is infamous around these partsthiru is infamous around these partsthiru is infamous around these partsthiru is infamous around these partsthiru is infamous around these partsthiru is infamous around these parts
I've had a couple of CD changers that try and eject the magazine when the button is pressed, but they get stuck, because they wedge on something, s2o they need levering out instead. Which is different from the CDs not playing properly. Is this the same for you?
______________________________________
discount audio cables
Elektrisches Skateboard
"The JC"
15
Dec 14, 2010 12:42 PM
sayegh87
Mar 31, 2010 03:53 PM
jpohl402
Jun 10, 2008 12:57 PM
Fastback
The Teamspeed Music Forum
Feb 23, 2008 12:20 PM
