California wants to do away with oil changes...sort of
Old Dec 16, 2011 | 04:13 PM
Manettino's Avatar
Manettino is a name known to allManettino is a name known to allManettino is a name known to allManettino is a name known to allManettino is a name known to allManettino is a name known to allManettino is a name known to allManettino is a name known to allManettino is a name known to allManettino is a name known to allManettino is a name known to all
Post California wants to do away with oil changes...sort of
Source: State hopes to break car owners' habit of changing oil too often - latimes.com
California launches a campaign against the widespread notion that oil changes are needed every 3,000 miles. Officials say the practice wastes millions of gallons of oil a year.
By Jerry Hirsch, Los Angeles Times
December 15, 2011
Many automobile owners are spending more than they need on motor oil, believing that it should be changed every 3,000 miles even though almost no manufacturer requires such an aggressive oil-change schedule.
The long-held notion that the oil should be changed every 3,000 miles is so prevalent that California officials have launched a campaign to stop drivers from wasting millions of gallons of oil annually because they have their vehicles serviced too often.
"Our survey data found that nearly half of California drivers are still changing their oil at 3,000 miles or even sooner," said Mark Oldfield, a spokesman for the California Department of Resources, Recycling and Recovery, which has launched the Check Your Number campaign to encourage drivers to go with the manufacturer's recommendations.
Improvement in oils, friction proofing and car engines have lengthened the oil-change interval, typically 7,500 miles to 10,000 miles for most vehicles.
Changing motor oil according to manufacturer specifications would reduce motor-oil demand in California by about 10 million gallons a year, the agency said. The state has created a website, checkyournumber.org, where drivers can look up the suggested motor-oil change interval number for their vehicles.
The agency and other groups said slashing motor-oil consumption would be good for the environment and won't hurt the longevity or reliability of autos.
"Drivers have a number of ways to reduce the environmental impact of their vehicles, which can also save them money," said Don Anair, senior engineer at the Union of Concerned Scientists.
Besides following the manufacturers recommendations for oil changes, drivers can reduce oil consumption by keeping their tires properly inflated and by avoiding idling their engines, Anair said.
"The 3,000-mile oil change just says that the marketing campaign by quick-lube companies has been effective," said Steve Mazor, manager of the Auto Club of Southern California's Automotive Research Center. It made sense years ago, when "we had cast-iron block engines with cast-iron pistons that would expand when they got hot and older lubricants," Mazor said.
Nationally 51% of vehicle owners said they believe oil should be changed every 3,000 miles or three months, according to an August survey by market research firm NPD Group. And just 33% wait more than 4,000 miles between oil changes, NPD said.
Drivers should be confident in the oil service advice offered by automakers, Mazor said.
Vehicle warranties, especially for power trains, have grown longer in recent years, he noted, and automakers would not give advice that could hurt engines and increase their warranty expenses.
Ford Motor Co. recommends oil changes for most of its new vehicles at 10,000 miles, although some still require the service at 7,500 miles.
"Our new generation of engines have tighter internal tolerances, which reduces the amount of carbon and other products from combustion that gets into the oil," said Richard Truett, a Ford spokesman.
The latest engines also run at more optimum temperatures, which diminishes the degradation of oil.
Honda Motor Co. and its luxury marque, Acura, no longer have a set interval for motor-oil changes.
Both Honda and Acura vehicles are equipped with a maintenance minder system that recommends oil changes and other services based on a number of vehicle-usage factors, including mileage and climate. Other manufacturers have similar systems that alert drivers to the need for an oil change.
"The idea is to prevent either over- or under-maintaining a car by following a set schedule," said Chris Martin, a Honda spokesman. "Now, there is no guesswork."
Typically, the indicator for an oil change lights up every 5,000 to 10,000 miles in Honda and Acura vehicles.
Owners of late-model BMWs can go as many as 15,000 miles between oil changes, depending on driving conditions. BMWs also have sensors alerting drivers to the need to change motor oil based on conditions like driving in stop-and-go traffic, making short trips and prolonged idling.
Despite these improvements, many drivers insist on changing the oil often even if it isn't recommended.
This has prompted some new car dealers to ask customers who come in for an oil change when it's not recommended to sign a document stating that they understand that the maintenance guidelines for their auto don't require a change at that time. The dealers are worried that someone might later accuse them of selling unnecessary maintenance services.
Old Dec 16, 2011 | 04:24 PM
STOPPIE's Avatar
Teamspeed's Howitzer
You'd be shocked how many people don't understand oil changes.
Old Dec 16, 2011 | 05:01 PM
Axxlrod's Avatar
Axxlrod has a reputation beyond reputeAxxlrod has a reputation beyond reputeAxxlrod has a reputation beyond reputeAxxlrod has a reputation beyond reputeAxxlrod has a reputation beyond reputeAxxlrod has a reputation beyond reputeAxxlrod has a reputation beyond reputeAxxlrod has a reputation beyond reputeAxxlrod has a reputation beyond reputeAxxlrod has a reputation beyond reputeAxxlrod has a reputation beyond repute
I have a buddy that owns 12 Jiffy Lube stores. He's not gonna be happy.
Of course, he's probably chillin on his 80' boat right now... I don't feel very bad for him.
Old Dec 16, 2011 | 06:15 PM
Tsar's Avatar
Yea, boobs never hurt.
My mother changes her synthetic oil every 3k miles because that's what TV says. I've tried to correct this behavior, but then I said "screw it".
Old Dec 16, 2011 | 07:22 PM
mannnu81's Avatar
I change out at 7500-10000 already. I'm glad the rest of the world see it the way I do
Old Dec 17, 2011 | 01:27 AM
djantlive's Avatar
djantlive has a reputation beyond reputedjantlive has a reputation beyond reputedjantlive has a reputation beyond reputedjantlive has a reputation beyond reputedjantlive has a reputation beyond reputedjantlive has a reputation beyond reputedjantlive has a reputation beyond reputedjantlive has a reputation beyond reputedjantlive has a reputation beyond reputedjantlive has a reputation beyond reputedjantlive has a reputation beyond repute
this is a great thing. too many people waste resources.
Old Dec 17, 2011 | 09:51 AM
VKING's Avatar
Nissan recommends every 3 months or 6,000 kms and so do most import manufacturers in southern ontario. That being said depending on how far you drive in a 3 month period will dictate when you should change it. Climate might have something to do with it! But I do know this if a customer elects to change his or her oil every 12,000kms they are asking for trouble in the long run! These engines get really hot and can't handle the long oil change interval . Even mobil one recommends every 6,000kms. It's the cheapest maintenance you can do for your 2nd biggest investment! Why wouldn't you?
Old Dec 17, 2011 | 10:22 AM
STOPPIE's Avatar
3 months? are they out of their minds?
Old Dec 17, 2011 | 01:23 PM
VKING's Avatar
That's the menu! I tell people if your not putting the kms on it during that time stretch it to at least 4 months!. Let's face it we want them coming back as much as possible! That's how we eat!
Old Dec 17, 2011 | 01:29 PM
STOPPIE's Avatar
Are you fvcking with me right now? So you're okay with lying? Car doesnt need an oil change that often.
