996 GT2 (Rear) Window Tint Removal?
Old Jan 23, 2010 | 12:01 PM
911dr's Avatar
911dr is an unknown quantity at this point
996 GT2. What is the absolute best method or service to remove window tint from the rear window? Preventing damage to the window defroster heat filaments is a concern.
Old Jan 23, 2010 | 12:13 PM
TeutonicCarFan's Avatar
Carefully with a razor blade, it takes forever. Then you have to go over it with something to remove the goo (supersol). Obviously, don't take the razor across any of the elements, work between the elements and try to peel from the film as much as possible.
Old Jan 23, 2010 | 12:55 PM
Clubber's Avatar
I use steam gun (not heat gun) . It really makes it super easy and safe to remove. Just direct to the the part you are peeling and the tint will simple let go of the window.
Old Jan 23, 2010 | 07:19 PM
Clever Nickname's Avatar
Clever Nickname You are a Teamspeed member that Rocks and Rolls!Clever Nickname You are a Teamspeed member that Rocks and Rolls!Clever Nickname You are a Teamspeed member that Rocks and Rolls!Clever Nickname You are a Teamspeed member that Rocks and Rolls!Clever Nickname You are a Teamspeed member that Rocks and Rolls!Clever Nickname You are a Teamspeed member that Rocks and Rolls!Clever Nickname You are a Teamspeed member that Rocks and Rolls!Clever Nickname You are a Teamspeed member that Rocks and Rolls!Clever Nickname You are a Teamspeed member that Rocks and Rolls!Clever Nickname You are a Teamspeed member that Rocks and Rolls!Clever Nickname You are a Teamspeed member that Rocks and Rolls!
Just say "no" to razor blades... Spray the inside of the window with a water/soap solution then tape a black, plastic bag to the entire inside of the window, letting it sag a bit. Leave it in the sun to evaporate and then gently remove the glue residue. with some microfibers and if necessary some glue remover.
Old Jan 24, 2010 | 11:05 AM
Auto Concierge's Avatar
I have as well used my steamer in this manner, once you get a corner to lift it will come off.
Laelops
Sep 30, 2012 07:59 PM
Marc
30
Feb 17, 2011 12:33 PM
BlakeNW
Feb 4, 2011 02:47 PM
Hussain
Aug 26, 2010 02:14 PM
pnoob2
Jun 20, 2010 10:48 PM
