FS: PerformanceBox (Pbox)
Old Jun 10, 2012 | 03:48 PM
DEEPBLUE's Avatar
DEEPBLUE has a reputation beyond reputeDEEPBLUE has a reputation beyond reputeDEEPBLUE has a reputation beyond reputeDEEPBLUE has a reputation beyond reputeDEEPBLUE has a reputation beyond reputeDEEPBLUE has a reputation beyond reputeDEEPBLUE has a reputation beyond reputeDEEPBLUE has a reputation beyond reputeDEEPBLUE has a reputation beyond reputeDEEPBLUE has a reputation beyond reputeDEEPBLUE has a reputation beyond repute
Almost new in box, used this a couple times to help tune the car, amazing device for measuring performance, logging, hp calculations (pretty accurate), lap timing etc.
The PerformanceBox is suited to:
• Straight-line performance: 0-60, 0-100, 60-130, 60-0, 0-100-0, ¼-mile etc.
• Horsepower calculation: calculate both wheel and flywheel HP.
• Lap Timing: using GPS, there is no need for an external lap timing beacon. Accurate to 1/10th of a second.
• Speed and Compass display: use it as a super-accurate speedometer, updating 10 times per second, to calibrate or verify your vehicle's speedometer.
No matter how you use the PerformanceBox, it logs your speed, position, G-forces, and distance to its memory card ten times every second for detailed analysis in the included software.
View your performance and lap data on the PerformanceBox's built-in display, and log all your data to the SD memory card. Saved data files can easily be stored and compared, to see the difference between cars, drivers, parts, or setups.
Contents:
• PerformanceBox GPS data logger
• Windscreen suction mount and suction cups
• In-car power supply - connects to 12V aux socket
• Software/manual CD
Retails $570, Selling for $400 Shipped.
(PerformanceBox - Datalogger and Performance Meter)
Old Jun 10, 2012 | 07:48 PM
DEEPBLUE's Avatar
This has been sold, thank you!
