Jaguar XE SV Project 8 is the “Most Powerful, Agile and Extreme Performance Jaguar Road Car Ever Produced.”
Track-focused Jaguar super sedan has a 592-horsepower supercharged V8 and the aero add-ons, stopping power, and performance upgrades to go with it.
The Jaguar XE SV Project 8 from the company’s Special Vehicle Operations (SVO) division is more than just a small car with a big engine in it. Every part of it’s been reworked for higher speed and better performance, particularly on the track.
To make Jaguar’s smallest sedan lighter and more aerodynamically efficient, SVO replaced the front bumper and fenders with carbon fiber units. They also bolted on a manually adjustable two-position carbon fiber front splitter. The side skirts, rear bumper, and diffuser are made out of the same lightweight material. Project 8’s flat underbody further manages airflow. The manually adjustable two-position rear wing keeps the rear end stuck to the road and road course. SVO’s use of a carbon fiber hood with an integrated air extraction duct cut 6.6 pounds alone. They put the exhaust on a diet by opting for a titanium setup. All of those adjustments add up to a claimed weight of 3,847 pounds.
Up front, there’s a super-high-output version of Jaguar Land Rover’s well-known supercharged 5.0-liter V8. Retuned engine calibration software and better intake and exhaust airflow helps it crank out 592 horsepower – a record amount of ponies for a Jag road car – and 516 lb-ft of torque. Sixty mph comes up on the speedo in 3.3 seconds. Top speed? 200 mph even.
The enhanced V8 is coupled with a re-tuned eight-speed Quickshift auto. Gear changes take place in 200 milliseconds. All-wheel drive with an Electronic Active Differential that controls torque delivery to the rear tires applies the engine’s abundant power to the ground. Torque Vectoring by Braking tech clamps down on individual inside brake discs during cornering to make Project 8 more agile.
Manually adjustable Continuously Variable Shock Absorbers lower Project 8 by 15 mm for track days. Jaguar’s new Carbon Ceramic Brake (CCB) system officially debuts on Project 8, which features 15.7-inch two-piece front discs with six-piston calipers and 15.6-inch two-piece rear discs with one-piston sliding calipers. Those discs sit behind 20-inch forged aluminum alloy wheels with silicon nitride ceramic bearings a la Formula 1.
Project 8’s cockpit is trimmed with Alcantara and glossy carbon fiber accents. Tech includes a 4G Wi-Fi hotspot and a 12.3-inch TFT instrument panel display with full-screen 3D Map View nav. The cabin also showcases two firsts. The Pistolshift lever is new to the XE sedan; Track Mode, which recalibrates the Intelligent Driveline Dynamics, Adaptive Dynamics, Dynamic Stability Control, ABS, Torque Vectoring by Braking, and EPAS systems for track use, is a first for Jaguar. North American buyers will only be able to order Project 8 as a four-seater. Customers in other markets will be able to get their Project 8s as two-seaters with carbon fiber racing buckets, four-point harnesses, and a harness retention hoop in place of the rear seats.
Project 8 will officially debut on June 30 during the Goodwood Festival of Speed. Jaguar/SVO will only make 300 of them – all with left-hand drive. Expect prices to be in line with that kind of exclusivity.
