Clutch problem I m having a problem about the range my clutch have it is a very short range and the pedal is too high what do i do? The clutch model is spec stage 3+ |
What's the car? What's the clutch manufacturer or part number? |
I have a 09 porsche 997turbo manual, and installed a clutch of brand spec stage 3 + and I'm less than 1 cm to control. and the pedal is too loud |
Did you change the flywheel to match the clutch? Edit: Is this what you bought? http://www.specclutches.com/643783/s...7-sp843-529839 |
I bought this was SPEC Clutch Stage 3+ - Porsche 997 2007-2009 3.6L turbo SPEC Clutch SP843F the steering wheel was not changed and thanks for the help |
No problem. Is the car modified otherwise? If so, how and how much power? I meant the flywheel, it looks like this: https://cimg0.ibsrv.net/gimg/www.tea...ebff5b5ef7.jpg Edit: Also, did you get a sprung or unsprung disc? |
