:: ECS Tuning :: We've Gone MINI|Specials, and New Products
Old 02-17-2017, 05:47 PM
ECS Tuning - BMW's Avatar
ECS Tuning - BMW will become famous soon enoughECS Tuning - BMW will become famous soon enoughECS Tuning - BMW will become famous soon enoughECS Tuning - BMW will become famous soon enoughECS Tuning - BMW will become famous soon enoughECS Tuning - BMW will become famous soon enoughECS Tuning - BMW will become famous soon enoughECS Tuning - BMW will become famous soon enough
ECS Tuning
BMC Air Filter Now @ ECS
BMC air filters are produced using a "Full Molding" system that enables the characteristic red filter to be realized from a single mold with no welded joints thus avoiding easy breakage. The rubber used in BMC air filtering systems has a long life, is very durable and has optimum adhesion characteristics to all shapes of airboxes.
BMC filters are made of a multi-layered cotton gauze soaked with low viscosity oil covered with an epoxy coated alloy mesh to ensure protection from petrol fumes and oxidization due to air humidity.
All BMC air filters are pre-oiled, and they can be washed and regenerated by using the appropriate BMC regeneration kit.
**Original equipment for MINI Cooper JCW Sounds kit in your Gen 1 MINI!!**
Click HERE For MINI Cooper Options
  #362
Old 02-23-2017, 05:33 PM
ECS Tuning
Assembled By ECS For Your Gen 1 MINI
These are all-in-one kits that take the guesswork out of what you really need to keep your MINI performing at its best. From full Cooling System Refreshes, Oil Service Kits, to Automatic Transmission Services kits.
Specifically put together by ECS Tuning specialists, Assembled by ECS kits give you the piece of mind that the job is complete.
Change and Save
Fits:
R50 MINI Cooper 2002-2006
R53 MINI Cooper S/JCW 2002-2006
R52 MINI Cooper Convertible /S/JCW 2005-2008
Assembled By ECS For Your Gen 2 MINI
Fitment:
R56 MINI Cooper S/JCW (2007-2013)
R55 MINI Clubman S/JCW (2008-2015)
R57 MINI Cooper Convertible S/JCW (2009-2015)
R58 MINI Coupe' S/JCW (2012-2015)
R59 MINI Roadster S/JCW (2012-2015
Assembled By ECS For Your Gen 2 MINI Countryman / Paceman
On sale for a limited time
Fits: ( Cooper S & All4 only)
R60 MINI Countryman S/SX(ALL4) (2011+)
R61 MINI Paceman S/SX(ALL4) (2013+)
Assembled By ECS For Your Gen 3 MINI
These are all-in-one kits that take the guesswork out of what you really need to keep your MINI performing at its best. From full Brake Fluid Flush Kits, Oil Service Kits, to a Vinyl Wrap Install Kit.
Specifically put together by ECS Tuning specialists, Assembled by ECS kits give you the peace of mind that the job is complete.
Fits:
F55 MINI Cooper S 2015+
F56 MINI Cooper S/JCW 2014+
F57 MINI Cooper Convertible S/JCW 2016+
F54 MINI Clubman S/ All4/JCW 2016+
  #363
Old 03-01-2017, 05:46 PM
ECS Tuning
Powerflex For Your Gen 1 MINI
Sharpened handling. Increased agility. Tactile responsiveness. A feeling of being one with car and road. Replacing stock bushings with Powerflex polyurethane components will deliver all that and more.
ECS is proud to carry the Powerflex brand of performance bushings. Powerflex is a world-renowned name in high-performance products, and they manufacture an array of quality suspension and chassis components.
From subframe mounts to control arm and sway bar bushings and more, nothing overpowers the Powerflex catalog and their reputation for durability and quality.
Fits:
R50/R52/R53 MINI Cooper /S/JCW '02-'08
Click HERE For Gen 1 MINI Cooper Options
Powerflex Polyurethane Bushings For Your Gen 2 MINI
Fitment:
Click HERE For Gen 2 MINI Cooper Options
Powerflex Polyurethane Bushings For Your Gen 3 MINI
Fits:
F54-F57 MINI Cooper /S/JCW 2014+
Click HERE For Gen 3 MINI Cooper Options
  #364
Old 03-06-2017, 05:08 PM
ECS Tuning
Ziza LED Kits For Your Gen 3 MINI
Make night time, the right time. Let your MINI look great after hours with new LED lighting upgrades from Ziza.
Light a little; light a lot. Choose individual zone lighting changes at glove box, trunk, or reverse lights. Or grab all three to complete the interior/exterior rear lighting package and banish dirty yellow light from your MINI, once and for all.
These LEDs are as easy to install as standard bulbs. Their improved illumination and upscale look will be a welcome addition to any interior/exterior.
Fits:
F55 MINI Cooper /S 2015+
F56 MINI Cooper /S/JCW 2014+
F57 MINI Cooper Convertible /S/JCW 2016+
Click HERE For MINI Cooper Ziza Options
AAE Power Steering Pumps R50 R52 R53 MINI
The MINI power steering pump and power line repair kit was made to repair both the return and suction line that are located between the power steering pump and reservoir. This repairs the common power steering loss and failure due to a failed pump or leaking lines.
Choose from three levels of power steering pump repair kits, from just the replacement pump to the complete power steering system overhaul.
Each pump is re-manufactured here in the USA using ZF parts, the reliable OEM manufacturer.
Get your power steering back.
Fits:
R50 MINI Cooper (2002-2006)
R52 MINI Cooper / S / JCW ( 2005-2008 )
R53 MINI Cooper S / JCW ( 2002-2006 )
  #365
Old 03-09-2017, 10:51 AM
ECS Tuning
K-MAC For Your MINI Cooper
Factory stock suspensions bring increased tire wear and more frequent tire replacement, as a “full alignment” consists only of rudimentary toe-angle adjustment.
For over forty years, K-MAC has been hard at work developing a solution to this problem with patented innovations in camber/caster plates and bushing kits, allowing easy adjustment for a true “full four-wheel alignment” to be performed by any competent shop or individual.
KMAC gives you the ability to have your suspension properly dialed in for your use.
Fits:
R56 MINI Cooper /S/JCW'07+
R55 MINI Clubman /S/JCW '08+
R57 MINI Cooper Convertible /S/JCW '09+
R58 MINI Coupe' /S/JCW '12+
R59 MINI Roadster /S/JCW '12+
Click HERE For MINI Cooper Gen 2 Options
Gen 1 MINI Cooper
Fits:
R50-R53 MINI Cooper/S/JCW (2002-2008)
Click HERE For MINI Cooper Gen 1 Options
Gen 2 MINI Countryman / MINI Paceman
Fits:
R60 MINI Countryman /S/SX(All4)/JCW 2011+
R61 MINI Paceman /S/SX(All4)/JCW 2013+
Click HERE For MINI Cooper Gen 2 MINI Countryman/ Paceman Options
Alzor Wheels For Your Gen 3 F56 MINI Cooper
These new sets of Alzor Style wheels will not only change the look of your vehicle, but also capture the attention of others. The multi-classic to modern styles wheels will give your car a sleek appearance that will keep people looking as you pass.
Designed to bolt right up to your car, these wheels fit without any hassle.
If you want to achieve an extreme look, don't forget to check out our large assortment of ECS Tuning wheel spacers and lug bolts.
Stylize your MINI
Fits:
F56 MINI Cooper /S '14+
  #366
Old 03-14-2017, 05:55 PM
ECS Tuning
Canton Racing Products For Your MINI R52/R53
This coolant expansion/power steering tank combo fixes two problems with one kit. The coolant tank features a billet radiator style neck which accepts the Canton Racing part #81-030 pressure cap or any 30 psi radiator style cap. While the power steering tank comes with a cap, it is the mirror match in quality as the coolant tank. Both tanks mount to the factory location brackets on the back of the firewall.
Now in new wrinkle black powder coating finish!
Never worry again about a separating expansion tank and a leaky power steering tank. Solve two problems with this one kit.
Fits:
R52 MINI Cooper Convertible S / JCW 2005-2008
R53 MINI Cooper S / JCW 2002-2008
  #367
Old 03-15-2017, 04:03 PM
On all Koni sets purchased from now until May 31st, 2017 get up to $70 back in KONI rebate CASH!
Click HERE to shop KONI
  #368
Old 03-21-2017, 12:12 PM
ECS Tuning
MINI Cooper + Forge Motorsport
Forge Motorsport has developed a reputation for premium performance upgrades that address oftentimes overlooked areas of your vehicle.
ECS offers an extensive range of some of the most impressive Forge products for your MINI Cooper.
The alloy power assisted steering fluid tank is a stunning piece, dressing up your engine bay while increasing the durability and longevity of the unit for most models.
The stock rubber hoses on the MINI can often split, swell, and break over time. Forge offers chemical and corrosion-resistant silicone intake hoses, available in Red, Black, and Blue for most models.
See additional fitments below.
Gen 1 MINI Coopers
Fits:
Fits:
R52 MINI Cooper Convertible (2005-2008)
Gen 2 MINI Coopers
N14 Engines
Fitment:
R56 MINI Cooper S (2007-2010) JCW (2009-2012)
R55 MINI Clubman S (2008-2010) JCW (2009-2012)
R57 MINI Cooper Convertible S (2009-2010) JCW (2009-2012)
R58 MINI Coupe' JCW (2012)
R59 MINI Roadster JCW (2012)
N18 Engines
Fitment:
R56 MINI Cooper S (2011-2013) JCW (2013)
R55 MINI Clubman S (2011-2015) JCW (2013-2015)
R57 MINI Cooper Convertible S (2011-2015) JCW (2013-2015)
R58 MINI Coupe' S (2011-2015) JCW (2013-2015)
R59 MINI Roadster S (2011-2015) JCW (2013-2015)
N18 Engines
MINI Countryman/MINI Paceman
Fitment:
R60 MINI Countryman S/SX(All4)/JCW 2011+
R61 MINI Paceman S/SX(All4)/JCW 2013+
Gen 3 MINI Coopers
F54-F57
Fits:
  #369
Old 03-28-2017, 04:46 PM
ECS Tuning
Wheel Options For Your MINI Cooper
These sets of Alzor, NM Engineering, AC Schnitzer, 3SDM, ENKEI, F1R, BBS, HRE, 3SDM, and fifteen52 (and many others) wheels will not only change the look of your vehicle, but also capture the attention of others. The multi-classic to modern styles wheels will give your car a sleek appearance that will keep people looking as you pass.
Designed to bolt right up to your car, these wheels fit without any hassle. Of course, if you want to achieve an extreme look, don't forget to check out our large assortment of ECS Tuning wheel spacers and lug bolts.
For Your Model MINI click the links below to see what brands we have to offer::
Gen 1 MINI:
Fitment:
R50-R53 MINI Cooper /S/JCW (2002-2008)
Click HERE For R50-R53 MINI Cooper /S/JCW Options
Gen 2
Fitment:
R56 MINI Cooper /S/JCW (2007-2013)
R55 MINI Clubman /S/JCW (2008-2014)
R57 MINI Cooper Convertible /S/JCW (2009+)
R58 MINI Coupe' /S/JCW (2012+)
R59 MINI Roadster /S/JCW (2012+)
Click HERE For R55-R59 Options
Fits:
Click HERE For MINI Country/Paceman options
Gen 3 MINI
Fits:
F56/F57 MINI Cooper /S '14+
Click HERE For F56/F57 MINI Cooper /S Options
Gen 3 MINI
Fits:
F55 MINI Cooper /S (2015+)
Click HERE For F55 MINI Cooper /S Options
Gen 3 MINI
Fits:
F54 MINI Clubman /All4/S/ALL4 S (2016+)
Click HERE For MINI Clubman Options
  #370
Old 04-04-2017, 02:44 PM
ECS Tuning
New Ziza LED Kits For Your F54 MINI Clubman
Light a little; light a lot. Choose individual zone lighting changes at glove box, front parking, or reverse lights. Or grab all three to complete the interior/exterior rear lighting package and banish dirty yellow light from your MINI, once and for all.
Fits:
F54 MINI Clubman /S/JCW '16+
Euro Impulse Weighted Shift Knobs For Your MINI
Shift some excitement into your MINI with a Euro Impulse weighted aluminum shift knob, now available at ECS Tuning!
With a weight of just under 300 grams, this solid aluminum custom weighted shift knob allows for easier shifts, and improves the overall interior look of your MINI.
A Great Impulse
Fits:
MINI 6 speed manual transmission
R52/R53-R59 Models
MINI R52,R57 Convertible Top Rear Trunk Moldings
Exposure to sunlight, dirt, and harmful chemicals ages your convertible trim moldings located on the back of the convertible top. Eventually, these will crack and leak.
Don't wait for chemicals and dirt to permanently damage your trunk's interior and its valuable contents.
The Genuine MINI convertible top molding kits come with everything you need to do a professional-grade fix using common hand tools.
Zero cutting, fitting, or trimming required. This complete repair solution includes all the screws and hardware you'll need for a painless installation.
Fix it
Fits:
R52 MINI Cooper Convertible /S/JCW (2005-2008)
R57 MINI Cooper Convertible /S/JCW (2009-2015)
Quick Reply: :: ECS Tuning :: We've Gone MINI|Specials, and New Products
