Panamera Brakes - PCCB questions...
Old Dec 5, 2011 | 12:35 PM
mile2424's Avatar
mile2424 You are a Teamspeed member that Rocks and Rolls!mile2424 You are a Teamspeed member that Rocks and Rolls!mile2424 You are a Teamspeed member that Rocks and Rolls!mile2424 You are a Teamspeed member that Rocks and Rolls!mile2424 You are a Teamspeed member that Rocks and Rolls!mile2424 You are a Teamspeed member that Rocks and Rolls!mile2424 You are a Teamspeed member that Rocks and Rolls!mile2424 You are a Teamspeed member that Rocks and Rolls!mile2424 You are a Teamspeed member that Rocks and Rolls!mile2424 You are a Teamspeed member that Rocks and Rolls!mile2424 You are a Teamspeed member that Rocks and Rolls!
Do the size of the brakes vary on the different Panamera models, base, S, Turbo when choosing PCCB?
I know the Turbo has bigger brakes than the S normally, but what about when ordering PCCB on any of the model's? Are they all 390mm disc's?
Old Dec 5, 2011 | 12:37 PM
STOPPIE's Avatar
Teamspeed's Howitzer
PCCB brakes/rotors are all the same dimensions regardless of the car.
May I suggest you ask ALL your panamera questions in ONE thread rather then starting new ones?
Old Dec 5, 2011 | 04:31 PM
KT's Avatar
KT
I give good hugs. Bo, you're first.
KT has a reputation beyond reputeKT has a reputation beyond reputeKT has a reputation beyond reputeKT has a reputation beyond reputeKT has a reputation beyond reputeKT has a reputation beyond reputeKT has a reputation beyond reputeKT has a reputation beyond reputeKT has a reputation beyond reputeKT has a reputation beyond reputeKT has a reputation beyond repute
Write ups on the GTS make it seem like it has bigger brakes/Turbo brakes. I thought they were different as well.
Old Dec 5, 2011 | 04:39 PM
STOPPIE's Avatar
PCCB for Panamera are all the same diameter. The GTS recieves the "Turbo" treatment in the brake and athsetics department.
Old Dec 5, 2011 | 04:40 PM
mile2424's Avatar
Well it sounds like the GTS/Turbo are bigger in size than those on the base/S, but I am guessing if you order PCCB, they are the same size regardless of which trim level Panny? That's how I understood STOPPIE's comment.
Old Dec 5, 2011 | 04:59 PM
STOPPIE's Avatar
Yes of course.
PCCB's are 15.35" front/ 13.78" rear-
Iron Rotors:
15.4" upfront for turbo
14.2" up front for all other model
Old Dec 5, 2011 | 05:02 PM
Hill's Avatar
Hill is a name known to allHill is a name known to allHill is a name known to allHill is a name known to allHill is a name known to allHill is a name known to allHill is a name known to allHill is a name known to allHill is a name known to allHill is a name known to allHill is a name known to all
how many threads is this guy going to start...
Old Dec 5, 2011 | 05:11 PM
STOPPIE's Avatar
FYI PCCB's are looking to be a delayed availability on Panamera right now. And they are not available on V6 Panamera.
Old Dec 5, 2011 | 05:14 PM
STOPPIE's Avatar
Talking
a lot. LOL
Old Dec 5, 2011 | 05:26 PM
Why would you want PCCBs on a car like the Panny? Seems to me like the only advantage would be during hard driving on a race track, which the Panny is definitely not suited for. Same goes for PCCBs on the Cayenne. Just makes no sense.
