Garage Heater
Old 01-28-2019, 04:33 AM
okoyo's Avatar
okoyo is an unknown quantity at this point
Garage Heater
I'm planning to buy a heater for my garage. I'm still not sure whether to go for gas or electric heaters. Does anyone have experience with garage heaters? And are you using gas or electric?
Old 02-01-2019, 01:13 AM
okoyo's Avatar
I've stumbled on this electric garage heater review. I noticed that the are way more expensive than ordinary portable space heaters. I don't understand why, but they really bend you over for them. I'm still looking for other options or any heaters under $100 that can work well in my 285 square feet garage
Old 02-06-2019, 04:00 PM
slik560's Avatar
slik560 has a spectacular aura aboutslik560 has a spectacular aura aboutslik560 has a spectacular aura aboutslik560 has a spectacular aura aboutslik560 has a spectacular aura aboutslik560 has a spectacular aura aboutslik560 has a spectacular aura aboutslik560 has a spectacular aura aboutslik560 has a spectacular aura aboutslik560 has a spectacular aura aboutslik560 has a spectacular aura about
Even a small portable heater from the hardware store would probably work for a normal garage. I have a $30 one that does a fairly good job if I keep the door closed. There is a garage-oriented forum that could provide a lot more feedback. GarageJournal.com is a great resource.
Old 08-11-2022, 06:14 AM
Sam Suomela's Avatar
Sam Suomela is an unknown quantity at this point
I think the simplest heather will work, but I don't understand why you need it. If you like to keep your car or other things inside you, I don't see the point of using heather and spending electricity on that. I chose a better and easiest option. I don't have a garage in my current yard, I ordered a carport from https://carportaustralia.com.au/cantilever-carport/, and it's the best decision. It looks even better than a garage and saves so much space; it's amazing. I recommend trying one for sure!
Old 10-06-2022, 12:01 PM
sermomon's Avatar
sermomon is an unknown quantity at this point
Even have a small heater better than don't have.
Old 10-27-2023, 11:32 AM
markaust972's Avatar
markaust972 is an unknown quantity at this point
I've used both gas and electric heaters in my <!--td {border: 1px solid #cccccc;}br {mso-data-placement:same-cell;}-->Richmond garage. Gas heaters tend to provide more powerful, rapid heat, but they require proper ventilation. Electric heaters are easier to install and safer, but they might take longer to warm up the space. It depends on your needs and setup.
HBdirtbag
Garage Forum
05-21-2012 03:39 PM
crazy1323
Garage Forum
15
01-23-2012 11:32 PM
Ian
Garage Forum
18
04-18-2011 01:26 PM
Ian
Garage Forum
03-31-2011 12:17 PM
RacerRick
Garage Forum
14
12-18-2008 10:19 AM
Quick Reply: Garage Heater
