Help with running front LED's on 997.2TT How do I get the front LED strip of lights to operate when in the OFF or daytime running light position ? Only the fogs come on in this position and I would like the LED's to be on as they were in my C2S. As a matter of fact the full bank of LED's don't come on in any of the lighting positions. In one of the positions only the 2 outer spot LED's come on. What are the rest of the LED lights for if they aren't functional ? Thanks |
You may need to do that through settings in your display. |
The LEDs are on when the headlights are off. They are the DRLs. I don't use the "Auto" setting since I don't trust it. When my lights are in the off position, the LEDs are definitely on. Even when the headlights are on, the LEDs are just less bright. |
That is how it was in my 09 C2S but now in the Turbo they don't come on in any of the lighting positions.....only the 2 fog lights come on in "Off" position. ?? |
3 lights Led, signal, headlights. daylight on setting off- Led 1st clockwise- signal 2nd clockwise- headlight+signal Daylight off off-no light same as above If I remember correctly... You can not turn led and signal on together and 997.2 turbo dont use led as fog light. So, you can not light up all 3 at the same time. Just driver side rear fog light is all. |
I appreciate the response but don't really understand the explanation ? |
Originally Posted by rocketman
(Post 641679)
| All times are GMT -4. The time now is 02:59 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
