2015 Corvette Z06 Order Guide Leaks Out
Old 08-19-2014, 07:39 PM
DJ is offline
Post 2015 Corvette Z06 Order Guide Leaks Out
Thanks to the team at Corvette Blogger we finally get a look at the full order guide for the all-new Corvette Z06, well everything but the price that is. As they note one of the most interesting specifications on the new super vette is it's surprising curb weight, which comes in at 3,524 lbs for the Coupe, and 3,582 lbs. for the drop-top.
Considering the 2013 Corvette Z06′s curb weight was 3,175 lbs, and 3,333 lbs. for the old ZR1, we are left scratching our heads a bit considering the 2015 Z06's use of a new aluminum frame structure.
Despite the added pounds, we wouldn't kick Big Nasty out of our garage and with 650hp under the front hood, we'll probably never notice the increased curb weight anyway!
PDF doc here -> http://www.corvetteblogger.com/docs/...rder-Guide.pdf
Old 08-20-2014, 09:30 AM
Ritesh's Avatar
3500+ Lbs!! WTH....Its the same weight as an F458, a M3/M4, and LP560 SL. That's a Porker.
Give me a 3000 lb car with 450 HP ANYDAY!!
Old 08-21-2014, 04:56 PM
brnsrgn's Avatar
Teamspeed's Official Brain Surgeon
brnsrgn has a reputation beyond reputebrnsrgn has a reputation beyond reputebrnsrgn has a reputation beyond reputebrnsrgn has a reputation beyond reputebrnsrgn has a reputation beyond reputebrnsrgn has a reputation beyond reputebrnsrgn has a reputation beyond reputebrnsrgn has a reputation beyond reputebrnsrgn has a reputation beyond reputebrnsrgn has a reputation beyond reputebrnsrgn has a reputation beyond repute
Getting HP to the ground is the problem. Cars need to get lighter to get better performance. Usable performance say under triple digits, minimal difference between a veyron and a 911 turbo s.
Bring on the era of sub 3000 lb sports cars!
Old 09-17-2014, 05:26 AM
Rob99's Avatar
Rob99 has a little shameless behaviour in the past
Here we go:
https://teamspeed.com/forums/gt/8378...ng-7-20-a.html
Old 09-17-2014, 08:54 AM
DJ is offline
^^Fixed that for you
The news is here as well mate.
Old 09-26-2014, 11:20 AM
koizu's Avatar
Old 09-26-2014, 12:13 PM
D.Liu's Avatar
D.Liu You are a Teamspeed member that Rocks and Rolls!D.Liu You are a Teamspeed member that Rocks and Rolls!D.Liu You are a Teamspeed member that Rocks and Rolls!D.Liu You are a Teamspeed member that Rocks and Rolls!D.Liu You are a Teamspeed member that Rocks and Rolls!D.Liu You are a Teamspeed member that Rocks and Rolls!D.Liu You are a Teamspeed member that Rocks and Rolls!D.Liu You are a Teamspeed member that Rocks and Rolls!D.Liu You are a Teamspeed member that Rocks and Rolls!D.Liu You are a Teamspeed member that Rocks and Rolls!D.Liu You are a Teamspeed member that Rocks and Rolls!
I tried to search out an answer for you guys for the question of weight.
Reinforced drive train with upgraded cooling to match
New control systems for active exhaust flaps
Upgraded cooling ducts for aero
More luxurious interior
Compliance with stricter EPA and pedestrian safety regulations
Supercharged engine
TiAgMC
08-22-2012 09:11 PM
terrence
11
11-13-2010 04:40 PM
Eric (Plug Guy)
07-16-2008 08:33 PM
jgolf53
07-03-2008 11:23 AM
Quick Reply: 2015 Corvette Z06 Order Guide Leaks Out
