Lingenfelter offers lineup of 2010 Chevrolet Camaro engine upgrades
Old 05-04-2009, 01:22 PM
DJ is offline
Post Lingenfelter offers lineup of 2010 Chevrolet Camaro engine upgrades
Press Release:
Lingenfelter 2010 Camaro Engine Packages:
550 BHP / 550 lbs-ft of torque
When Lingenfelter installs the Magnuson supercharger system we upgrade many components from the base Magnuson kit for better performance and reliability. Each car also gets Lingenfelter PCM programming that lets you benefit from the experience LPE has gained from installing hundreds supercharger systems since 2001 when we first started offering the Magnuson superchargers as a package.
Package includes:
- TVS2300 intercooled supercharger system- silver painted finish
- Based on OEM Eaton supercharger unit
- Properly sized fuel injectors
- Fuel system upgrades
- 160 Degree thermostat
- Boost bypass controller
- Lingenfelter High Flow Air Intake
- Professional installation, testing and calibration
- Corsa stainless steel cat back exhaust
- Chassis dyno report before & after installation
- Excellent drivability, highway mileage not adversely affected
- Lingenfelter 3 year/ 36,000 mile warranty
- Lingenfelter fender badges
- Lingenfelter certificate of authenticity
570 BHP / 570 lbs-ft of torque
Package includes:
650 BHP / 600 lbs-ft of torque
- Engine removal, disassembly and inspection
- Lingenfelter CNC porting of LS3 cylinder heads
- Lingenfelter multi-angle valve job, cc, surfacing & assembly
- Stainless steel intake valves and heavy duty Inconnel exhaust valves
- Competition Cams dual valve springs, titanium spring retainers, 10 degree locks
- JE Forged aluminum pistons and tool steel pins
- Manley 4340 forged steel “I” beam connecting rods
- Computer balanced LS7 forged steel crankshaft & rotating assembly
- File fit rings, heavy duty rod & main bearings, head gaskets, head bolts
- Fuel system upgrades and properly sized fuel injectors
- Ported & polished LS3 throttle body
- Boost by pass system
- Professional engine installation, testing & tuning
750 BHP / 685 lbs-ft of torque
- Chevrolet LS7 7.0 L aluminum block
- Chevrolet LS7 aluminum heads
- Chevrolet LS7 titanium connecting rods
- Chevrolet LS7 forged steel crankshaft - 4.000″ stroke
- Heavy duty inconnel exhaust valves
- Professional assembly and blueprinting of engine
800 BHP 800 lbs-ft of torque
- Callies 4340 forged steel crankshaft - 4.000″ stroke
- Lingenfelter CNC porting of LS7 cylinder heads
- Computer balanced crankshaft & rotating assembly
- Properly sized fuel injectors and high capacity fuel system
- Twin Garrett oil lubricated & liquid cooled true ball bearing turbochargers
- Lingenfelter turbo compressor housings & exhaust housings with integral waste gates
- Lingenfelter super high efficiency air to air charge coolers
- Lingenfelter 304 Stainless steel 4 into 1 custom exhaust manifolds & turbo outlets
- Lingenfelter belt driven turbocharger scavenge pump & turbo oil drain reservoir
- Lingenfelter custom molded silicone air ducts
- Two S&B 360 degree conical air filters
- Stainless steel / ceramic heat shields & stainless clamps
- Port matched LS7 intake manifold
Lingenfelter 2010 Camaro Body Kit:
Lingenfelter will be offering body enhancements for the new 2010 Camaro later this summer.
Enhancement package will include:
Front Fascia & Rocker Extension
Front Splitter
Grille Bar Insert with Wire Mesh Texture
Hood with Air Extractors
Rear Deck Lip Spoiler
Rear Fascia Extension with Exhaust Tips
Rear Tail Lamp Panel
Old 05-04-2009, 03:07 PM
miboxer96's Avatar
miboxer96 has a reputation beyond reputemiboxer96 has a reputation beyond reputemiboxer96 has a reputation beyond reputemiboxer96 has a reputation beyond reputemiboxer96 has a reputation beyond reputemiboxer96 has a reputation beyond reputemiboxer96 has a reputation beyond reputemiboxer96 has a reputation beyond reputemiboxer96 has a reputation beyond reputemiboxer96 has a reputation beyond reputemiboxer96 has a reputation beyond repute
Front lip looks bad.
Don't like the side skirts either.
But would love to drive it after the 800 HP modification.
They actually look pretty good on the road. Saw a few of them this weekend....Not the LPE version, but the stock version.
Old 05-04-2009, 03:11 PM
Gobbles's Avatar
Full of Win.
I don't see any chassis/suspension mods on those lists, especially not on the 800 BHP mod. That's what, twice the horsepower the chassis was designed for?
Old 05-04-2009, 03:15 PM
eshaun's Avatar
Should be a monster but maybe they can do something to fix that terrible retro modern styling...if I wanted retro i'd buy a 69 camaro. Ok I know looks are subjective but come to think of it the interior finish was better back then too...
Old 05-04-2009, 05:42 PM
jamie's Avatar
No prices?
Old 05-04-2009, 11:13 PM
Originally Posted by jamie
No prices?
+1. I wonder what the top spec kit costs...
I too, am surprised they don't have any chassis mods. Nothing about any extra bracing or upgraded suspension, much less brakes...
Old 05-05-2009, 01:10 AM
Shadow's Avatar
Not feeling the front lip to much and they definitely need to get some type of suspension upgrades, especially for the 800hp package. Other than that I would love to have one.
Old 05-05-2009, 06:48 PM
SINISTR's Avatar
SINISTR You are a Teamspeed member that Rocks!SINISTR You are a Teamspeed member that Rocks!SINISTR You are a Teamspeed member that Rocks!SINISTR You are a Teamspeed member that Rocks!SINISTR You are a Teamspeed member that Rocks!SINISTR You are a Teamspeed member that Rocks!SINISTR You are a Teamspeed member that Rocks!SINISTR You are a Teamspeed member that Rocks!SINISTR You are a Teamspeed member that Rocks!SINISTR You are a Teamspeed member that Rocks!SINISTR You are a Teamspeed member that Rocks!
Kinda ricer for my taste.
Old 05-05-2009, 07:10 PM
TTM0TION's Avatar
I want to see them in person, could be sick...power is insane...
Old 05-07-2009, 01:54 AM
chrissurfr's Avatar
chrissurfr has a reputation beyond reputechrissurfr has a reputation beyond reputechrissurfr has a reputation beyond reputechrissurfr has a reputation beyond reputechrissurfr has a reputation beyond reputechrissurfr has a reputation beyond reputechrissurfr has a reputation beyond reputechrissurfr has a reputation beyond reputechrissurfr has a reputation beyond reputechrissurfr has a reputation beyond reputechrissurfr has a reputation beyond repute
i love how tuners even speculate on cars before they build them now...
Bullitt44
Automobiles
05-16-2011 01:00 AM
Modern Muscle
19
09-09-2009 10:35 AM
Modern Muscle
04-14-2008 09:54 PM
Modern Muscle
03-18-2008 11:48 PM
Modern Muscle
03-17-2008 01:24 PM
Quick Reply: Lingenfelter offers lineup of 2010 Chevrolet Camaro engine upgrades
