Best garage door for salt water?
Old 06-25-2012, 02:36 PM
GLN's Avatar
GLN
GLN is offline
Thor Liked My Watch
Need some advice...
My parents have a house right on the beach and saltwater/rust is a huge issue.
Anything steel/metal seems to rust. New BBQ every single summer...
Now they're realized the garage door needs to be replaced or at least sanded/painted every 3 years or so...
I'm wondering if anyone else has encountered a similar problem, and what's the best route?
Is it generally cheaper to keep sanding/painting, or is there a better option?
Thinking about fiberglass or vinyl doors... One person told me fiberglass is the solution, but when I spoke to someone else about it, they told me its drastically more expensive, and though you wont ever have to repaint or sand it, you will have to have it re-coated with a protective finish every 2-3 years...
THX!
Old 06-25-2012, 02:49 PM
RDuke's Avatar
RDuke has a reputation beyond reputeRDuke has a reputation beyond reputeRDuke has a reputation beyond reputeRDuke has a reputation beyond reputeRDuke has a reputation beyond reputeRDuke has a reputation beyond reputeRDuke has a reputation beyond reputeRDuke has a reputation beyond reputeRDuke has a reputation beyond reputeRDuke has a reputation beyond reputeRDuke has a reputation beyond repute
I went with Haas doors (fiberglass and a high R-rating). I don't have exposure to salt water but they are holding up great and the price was very reasonable.
Old 06-25-2012, 03:11 PM
BOOST's Avatar
BOOST has a reputation beyond reputeBOOST has a reputation beyond reputeBOOST has a reputation beyond reputeBOOST has a reputation beyond reputeBOOST has a reputation beyond reputeBOOST has a reputation beyond reputeBOOST has a reputation beyond reputeBOOST has a reputation beyond reputeBOOST has a reputation beyond reputeBOOST has a reputation beyond reputeBOOST has a reputation beyond repute
I had the same problem, I just switched them out for Teak doors that open out...
Old 06-25-2012, 03:13 PM
yzracer931's Avatar
yzracer931 has a reputation beyond reputeyzracer931 has a reputation beyond reputeyzracer931 has a reputation beyond reputeyzracer931 has a reputation beyond reputeyzracer931 has a reputation beyond reputeyzracer931 has a reputation beyond reputeyzracer931 has a reputation beyond reputeyzracer931 has a reputation beyond reputeyzracer931 has a reputation beyond reputeyzracer931 has a reputation beyond reputeyzracer931 has a reputation beyond repute
Some sort of composite door would fix this issue.
Old 06-25-2012, 03:24 PM
gmaccormack's Avatar
Do they make them in aluminum?
Old 06-25-2012, 03:26 PM
That's what I was thinking. I bet aluminum doors are out there. If they can make siding out of the stuff, why not garage doors too?
Old 06-25-2012, 03:29 PM
BOOST's Avatar
Aluminium still oxidizes, So it would fall apart eventually.. The only option would be to use stainless steel, but the cost would be substantial...
Old 06-25-2012, 03:32 PM
I doubt anyone is using stainless. At least aluminum will last much longer then steel.
Old 06-25-2012, 03:39 PM
BOOST's Avatar
I have a set of stainless doors on a unit, Their great in certain respects... Cleaning ect..They look great as well. But the construction costs high..
(Not mine)
Old 06-25-2012, 03:54 PM
jox's Avatar
jox
jox is offline
Wow, very few homes could probably pull that stainless look off. It would have to be very modern.
While I am not fortunate enough to have an oceanfront property, I had a fiberglass door put in 2 years ago and it still holds up pretty nicely, being only 5 miles from the ocean and all
Quick Reply: Best garage door for salt water?
