what is the problem??
Old 03-13-2016, 01:12 PM
allanshere's Avatar
allanshere is an unknown quantity at this point
08 cayenne turbo 150000 km, had the starter and plugs changed at the same time. Now I am burning oil at a rate of one liter per 200 km ,I did not have this problem before...
Old 03-14-2016, 07:29 AM
Rob99's Avatar
Rob99 has a little shameless behaviour in the past
1,5L / 1000km oil consumption (5w-50 is recommended)
The rubber O-ring between the turbocharger and the charge air cooler was defective. In this case should be oil inside the hose to the air cooler.
The exploded drawing contains the component:
https://www.pff.de/porsche/index.php...-im-955-turbo/
Old 03-14-2016, 04:33 PM
allanshere's Avatar
thank you for the input but the hose to the cooler is oil free.
Old 03-15-2016, 04:06 AM
Rob99's Avatar
Turbochargers sealing problem? Blue smoke coming from the exhaust?
Z0RR0
Gadgets & Electronics | Home Theater | Gaming
02-05-2008 02:14 PM
Quick Reply: what is the problem??
