Cayman engine swap?
Old Feb 22, 2012 | 07:29 PM
The Automotive Aficionado's Avatar
The Automotive Aficionado is an unknown quantity at this point
When I originally thought about this I was of the mind set of just getting the rolling chassis and starting from there. The only thing I can't do is the body work. Everything else I am not going to worry about.
JCay, what are your ultimate plans for your project?
Old Feb 23, 2012 | 08:26 AM
Harris@TPCRacing's Avatar
Harris@TPCRacing You are a Teamspeed member that Rocks and Rolls!Harris@TPCRacing You are a Teamspeed member that Rocks and Rolls!Harris@TPCRacing You are a Teamspeed member that Rocks and Rolls!Harris@TPCRacing You are a Teamspeed member that Rocks and Rolls!Harris@TPCRacing You are a Teamspeed member that Rocks and Rolls!Harris@TPCRacing You are a Teamspeed member that Rocks and Rolls!Harris@TPCRacing You are a Teamspeed member that Rocks and Rolls!Harris@TPCRacing You are a Teamspeed member that Rocks and Rolls!Harris@TPCRacing You are a Teamspeed member that Rocks and Rolls!Harris@TPCRacing You are a Teamspeed member that Rocks and Rolls!Harris@TPCRacing You are a Teamspeed member that Rocks and Rolls!
With our 3.7L Turbo Cayman, we are at 600HP. Here is a video of the car on the dyno and also Mike explaining the dyno chart.
TPC Racing: 600HP 3.7L Cayman Turbo - YouTube
Also, here is the build thread I put together around Christmas time when we got the car running.
https://teamspeed.com/forums/boxster...dle-power.html
Old Feb 23, 2012 | 12:21 PM
Is the 3.7 based off of the Cayman block?
Old Feb 23, 2012 | 04:48 PM
We take the block from your Cayman and machine it to a 3.7
Old Feb 23, 2012 | 11:16 PM
Are the cylinder walls still thick enough to handle that power for the long run?
Old Feb 24, 2012 | 05:30 AM
JCay's Avatar
JCay has a reputation beyond reputeJCay has a reputation beyond reputeJCay has a reputation beyond reputeJCay has a reputation beyond reputeJCay has a reputation beyond reputeJCay has a reputation beyond reputeJCay has a reputation beyond reputeJCay has a reputation beyond reputeJCay has a reputation beyond reputeJCay has a reputation beyond reputeJCay has a reputation beyond repute
Sounds like a good plan.
My ultimate plan is to build the best porsche this side of a carrera gt. The car will be used on both street and track.
Old Feb 24, 2012 | 05:46 AM
pearlcoupeg35's Avatar
I love the idea and would do it if i had the cheese. I think a GT3 3.8 motor with titanium exhaust would fit quite nicely in my Cayman R
That being said, for a lot less money the same (or similar) horsepower numbers can be had by getting a TPC Turbo Kit on a nice Cayman S. Something to think about....
Old Feb 24, 2012 | 10:14 AM
Yes. There is a change in material when we have the block machined. For more detailed info on the specs, give Tom Chan a call at the shop 410.799.7223
Old Feb 24, 2012 | 12:19 PM
Oh you put new liners in it? Darton sleeves I take it?
NM2255
Aston Martin | Jaguar | Lotus
10
May 12, 2013 04:15 PM
Carrera
Jun 22, 2011 09:16 PM
ZAMIRZ
Feb 19, 2011 11:06 AM
