Reply
LinkBack Thread Tools Display Modes
  #71
Old 11-24-2011, 05:41 AM
speed21's Avatar
speed21 is an unknown quantity at this point
Thats a great write up. Very detailed. Looking very seriously at doing this mod myself...am in process of ordering parts. I take you didn't have the fvd wiring adaptor at that time hence the big job of merging the wiring? Also didn't realise there was so much work to get the park sensors changed over...yikes....i have those too. Don't suppose you also have any before/after shots of trimming the exhaust shields?
TIA.
__________________
Sharkwerks enhanced 2008 997TT GT Silver/Black,Protomotive tune,EP1 Europipe,Sachs 764 clutch.
Lifes to short so.....let the good times roll!
  #72
Old 11-24-2011, 08:33 AM
atomic80's Avatar
Photographer Extraordinaire
atomic80 has a reputation beyond reputeatomic80 has a reputation beyond reputeatomic80 has a reputation beyond reputeatomic80 has a reputation beyond reputeatomic80 has a reputation beyond reputeatomic80 has a reputation beyond reputeatomic80 has a reputation beyond repute
atomic80 has a reputation beyond reputeatomic80 has a reputation beyond reputeatomic80 has a reputation beyond reputeatomic80 has a reputation beyond reputeatomic80 has a reputation beyond reputeatomic80 has a reputation beyond reputeatomic80 has a reputation beyond reputeatomic80 has a reputation beyond reputeatomic80 has a reputation beyond reputeatomic80 has a reputation beyond reputeatomic80 has a reputation beyond reputeatomic80 has a reputation beyond reputeatomic80 has a reputation beyond reputeatomic80 has a reputation beyond reputeatomic80 has a reputation beyond repute
Send a message via AIM to atomic80 Send a message via MSN to atomic80
Thanks man...it was a very involved process as I mentioned in my write-up. Unfortunately I didn't take detailed pictures of the exhaust shields but you should be able to figure it out once you get them out. Just test fit them. We also had to use epoxy resin to get the old sensors to work with the newer bumper but I noticed that Suncoast said to contact them if you do have the sensors. I had no idea that they were offering this upgrade. Thanks for the heads up, I'm sure the FVD wiring makes it so much easier than having to order two new control modules!
__________________
A3 | 997TT | Scuderia | RR | Baja | K1200S
"Play is the exultation of the possible." -Martin Buber
  #73
Old 11-24-2011, 06:28 PM
speed21's Avatar
Quote:
Originally Posted by bonehead »
Looks great. But yeeesh. Didn't think it would be that labor intensive!
Hey Ed on your recent .2 bar/lights upgrade did you do it yourself? Any difficulties you wish to share? Also your rear quad pipes did you get larger diameter ones to take up the extra slack in the larger surrounds?
Quote:
No worries. Suncoast were promoting the kit on their website and it appeared on the surface to be a relatively straight forward exercise on the basis all the necessary parts were there but after reading your thread it seems if there are no .2 sensors in the kit then there's more to it than meets the eye. They did say i would need to use certain stuff off my old bar but no mention of sensor issues so I need to check with them to see if they are supplying new .2 sensors in the kit otherwise those brackets are going to need changing....yikes! I'm guessing you were able to prise them all off without damaging anything?
__________________
  #74
Old 11-24-2011, 07:36 PM
bonehead's Avatar
bonehead has a reputation beyond reputebonehead has a reputation beyond reputebonehead has a reputation beyond reputebonehead has a reputation beyond repute
bonehead has a reputation beyond reputebonehead has a reputation beyond reputebonehead has a reputation beyond reputebonehead has a reputation beyond reputebonehead has a reputation beyond reputebonehead has a reputation beyond repute
Send a message via AIM to bonehead
Quote:
Hey Paul. No, I didn't do the install myself. Otherwise, I'd still be in the garage swearing up a storm
I already had the larger quad pipes from BBi (89mm each) before the .2 bumper.
__________________
Ed
Quote:
Originally Posted by ktvegas »
I'm trying to be serious but all I can see is bonehead slamming someone's mom.
  #75
Old 11-25-2011, 12:54 AM
speed21's Avatar
Hey Paul. No, I didn't do the install myself. Otherwise, I'd still be in the garage swearing up a stormI already had the larger quad pipes from BBi (89mm each) before the .2 bumper.
Yeh looking at it i know what you mean. So best i torture my beater with this job. He might like it. Btw those 89mm drain pipes do the job nicely in filling out those larger.2 surrounds. I have the TA fig 8's like Atomic's which have kind of shrunk a little in those. Still nice..but..
__________________
  #76
Old 11-25-2011, 01:40 AM
bonehead's Avatar
Agreed. The larger exhaust outlets make it a bit problematic with smaller tips. From his pics, Jason's look pretty good, but obviously anything close to stock won't fill the ports very well.
__________________
Ed
  #77
Old 12-06-2011, 09:31 PM
JROD9496 is an unknown quantity at this point
Everything looks great and I love the color! Great detailed pics by the way too!
Reply
LinkBacks (?)
LinkBack to this Thread: http://teamspeed.com/forums/997-996-turbo/42935-diy-swapping-997-1tt-taillights-newer-997-2tt-led-taillights-my-turbo.html
Posted By For Type Date
997 mk I mk II ? - Porsche Club Russland - This thread Refback 01-22-2011 03:37 PM
997 mk I mk II ? - Porsche Club Russland - This thread Refback 01-22-2011 03:09 PM
911: 997.1Turbo-Heckanpassung-997.2 Turbo - Tuning & Umbau - PFF - porsche friends worldwide. This thread Refback 08-29-2010 03:28 AM
Swapping the 997.1 TT taillights to the newer 997.2 TT LED's This thread Refback 06-14-2010 10:11 AM
Porkers.co.uk ::: Porsche Forum This thread Refback 06-09-2010 02:36 AM
DIY: Swapping the 997.1TT taillights to the newer 997.2TT LED taillights on my Turbo! - Teamspeed.com This thread Refback 06-08-2010 10:23 PM
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are On
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2012, vBulletin Solutions, Inc.
Search Engine Optimization by vBSEO 3.6.0
Magellan JetsChartisSonic MSModulare WheelsShark WerksRoad Sport SupplyIntercity Lines TransportGlobal AutosportsEvosportRevozportSpeed ShowcaseCECLum TecPorsche Of North OlmsteadRoark IndustrialADV1 WheelsMA CarbonTechartIsringhausen ImportsTKX PerformanceTitan MotorsportsPenta OtoAutodynamicaYellowKornerSweetwaterForgiato WheelsSound EarphonesGemsbyJwadeMcLaren PhiladelphiaExecutive Paint ProtectionMisha DesignsPremier Mobile GroupFerrari of Ft. Lauderdale | Long IslandWheelsboutiqueRadar MirrorMaserati ManhattanLamborghini MiamiLand Rover Long IslandVorsteinerAutosport DesignsAce AlloyRDBLAHempstead FordNav-TVFly The WhaleLou La VieWatches24SevenSupreme PowerCats exoticsMGP MotorsportBBI AutosportSasha PrimakFuchs PerformanceswitzerperformanceinnovationHennessey PerformanceChanpion PorscheSingature Car CollectionCampioni ShopThe Watch Collector NYPremier Financial ServicesWheel EnhancementTire RackRoslyn PorscheTunerworksNovitec RossoChampion Porsche/MotorsportVelos DesignwerksECS TuningHRE WheelsRenntechEscort Radarecurie25SR Auto GroupForgeline WheelsJaguar HuntingtonFabspeedBRM-ManufactureSwissvaxEvolution MotorSportsDetailing DynamicsRennen ForgedPrior Design NARays Volk RacingPorsche of the VillageReknownThe Rubin GroupPorsche of OrlandoDomani MotorsGosset Motor carsFerrari Maserati SeattleBumperplugs.comFumfie PhotoRSC TuningTPC RacingDonz ForgedNiche WheelsElite MotorsportsMaserati of CincinnatiIND Distribution
